Old 12-03-2016, 05:35 PM   #11
AquaMan's Avatar
Originally Posted by PineForestCamper View Post
Okay. I will go with your word on that. I am now entering my sixth hour today (total of 9) and I think we've turned the corner. Improvement every hour.
How about the fan/motor noise? Any input on that? This video is basically to hear the motor.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
AquaMan is online now   Reply With Quote
Old 12-03-2016, 06:07 PM   #12
Mine was making a terrible burnt plastic smell and had an intermittent noise. The first time at the dealership they ran it and said it was fine. it did it again and I asked them to pull the heater and check to see if the fan was hitting the "squirrel" cage inside. They found the fan blade was loose and periodically rubbing against the cage. It is also a Suburban model. Be persistent and have them pull it. I hang out at the dealership when they do most of my warranty work. They're excellent about letting me see what they fixed.
2015 Rockwood 8329SS TT
2004 Chevy 2500HD D/A 4X4 CC SB
Andersen Weight Distribution hitch
lakejumper is offline   Reply With Quote
Old 12-04-2016, 08:27 AM   #13
I have a new Forest River camper and the furnace gives off a burnt oil smell every time I turn it on. I have run the furnace 10 times for 20 minutes per time. The smell will not go away. Very frustrating! Any ideas?
Alpine207 is offline   Reply With Quote
Old 12-04-2016, 08:43 AM   #14
World Wide Wanderer
wahoonc's Avatar
Need to run it for more than 20 minutes. I run for a minimum of 30 minutes more if possible. For most furnaces that will take care of the smell issue, some take longer than others. On my last TT it took 30 minutes and I was good to go. On my current motor home it took over an hour the first time, then a couple more 30 minute sessions to get it cleared up. I suspect that they don't always do a good job of cleaning up during the manufacturing process.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 12-04-2016, 09:09 AM   #15
Georgia Frog Rally 2017
aceinspp's Avatar
The furnace should have burnt off any oil by now if you ran it as you said. Need to turn on high and let run for 30 min at least and open doors and windows to exit smoke or smell. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 12-04-2016, 09:53 AM   #16
SYE
SYE's Avatar
There is no oil in a camper or fifth wheel, maybe you are getting the new furnace smell, but it is not oil.
Scott & Vicki
2015 Silverado 3500HD 6.6L Duramax/Allison
2013 Columbus 295RL
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93 nights, 2017 58 Nights Reserved
SYE is online now   Reply With Quote
Old 12-04-2016, 10:12 AM   #17
Witch Doctor's Avatar
I purchased a new Forest River camper and every time I turn on the furnace, I get a very strong burnt oil smell. I have run the furnace 10 times for 20 minutes per time and the smell will not go away. Very frustrating. Any ideas?
If you ran the furnace till it got hot the light coating to stop rust should be gone. What you might be smelling is your blower motor. You not going to beable to tell unless you have a 12v amprobe to measure the amps on startup. You could be burning a start winding in it. That will smell like oil. Is your motor straining when it starts? Also since the R/A is not ducted you could be picking up the smell from something your storing, best guess I have....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 12-04-2016, 10:17 AM   #18
I had that smell for the first 1 1/2 hours of continuous use. Even had to take the battery out of the smoke detector for awhile. It should pass.
2017 Rockwood MiniLite 2506S
2016 Chevrolet HC 2500 6.6L
bshort is offline   Reply With Quote
Old 12-04-2016, 12:30 PM   #19
RV furnaces all stink when new. All the metal inside is coated with drawing oil (stamped parts) so it had to burn off. No big deal run it until is don't stink anymore and carry on....
SidecarFlip is online now   Reply With Quote
Old 12-04-2016, 01:01 PM   #20
Pretty loud, not normal
GMC Denali 2500HD 4x4
Columbus 381 FLC 2016
Flagstaff Ultralite 29 RLSS
2013 35 nights, 2014 105 nights, 2015 123 nights, 2016 18 nights 🙁
Mike ONeill is offline   Reply With Quote
furnace, noise
