Old 08-17-2017, 03:22 PM   #1
Furnace/ Thermostat Help
Hello folks,
Got a problem and need some help/advice. I have a 2005 Palomino Stampede. This past week were up in the UP of Michigan camping. It got a bit chilly at night and when I went to turn on the furnace, nothing happened. We made do with a couple of extra blankets. Got home and started trying to troubleshoot the problem. Fuse is good at the distribution panel. I then checked the t-stat by disconnecting the white wire and touched it to the red wire and nothing came on. I then touched the white wire to the green ground wire and the blower came on ran for about 20-30 seconds and then the heat kicked in and everything was working fine. I removed the white wire from the green terminal and it shut down after about 20-30 seconds. The t-stat is a Dometic Duo Therm analog t-stat. So am I correct in assuming my t-stat is bad since moving the temperature slider up and down does not turn the blower or furnace on? Second, the A/C is a constant On/Off with only Hi/Low Fan setting, so am I stuck with just replacing the analog t-stat or would a digital t-stat work for our camper. Everything in the camper is original. All seems to be working fine accept for the furnace issue with the t-stat.
Thanks in advance!
Art
2015 Chevy Silverado 2500HD LTZ, Crew Cab 4X4 Long Bed with the 6.6L Duramax/ Allison
2005 Palomino Stampede 23SLSD
Tank178 is offline   Reply With Quote
Old 08-17-2017, 03:43 PM   #2
Blackrock's Avatar
It's all on this website for changing out you analog for a digital Tstat.
RV Mods, Modifications, Parts, Tips, and Tech | ModMyRV
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 08-17-2017, 03:50 PM   #3
Head Rambler
It certainly sounds like the thermostat is the issue.
Is that thermostat for furnace only, or furnace and A/C?
There have been a lot of people replaced the heat/cool thermostats with household digital units, myself included and they work great.
Even if it's just furnace only, you can still use a digital household thermostat. You can get a heat only digital or a heat/cool unit. With the heat/cool unit you just won't use the cooling section of it.
Gotta go campin!
Old 08-18-2017, 06:37 PM   #4
Thanks for the replies. For now I'm just going to replace the t-stat with a stock one. Found it on Amazon and it will be here Monday.
Old 08-19-2017, 12:59 PM   #5
Digital is so much more accurate than the analog one you have now. I've had both, I'll never go back to analog!
Schvarak is offline   Reply With Quote
Old 08-21-2017, 04:28 PM   #6
The new t-stat arrived today and I installed it. Everything is working again! We have one more trip planned for Labor Day weekend, after that I will begin removing taking everything out and replacing the floor. We had a leak that went undetected until we started getting some soft spots in the floor. Maybe next year I will upgrade to a digital t-stat.
Quick question about the digital t-stats: The current T-stat and AC has just a constant On with a high and low setting for the fan. If I replace the stock t-stat, will a digital one work with the AC or am I stuck needing one with the Hi/Low switch on the side?
Old 08-21-2017, 05:59 PM   #7
The digital has hi/lo/auto fansettings which works with both A/C and heat. The good part about digital is it's easier to set the temp accurately without having to continually slide the temp up/down to get the right temp you want which is near impossible to do with the analog thermostats. I had any analog with my TT and sometimes it took me 4-5 or more attempts to set the right temp to make both me and the DW happy!! The analog slider was a PITA. Search online for Dometic Digital thermostats. I picked the one that had the right price - came in just a couple days. Also, you'll want to get that how to change from analog to digital thermostats mentioned before.
Old 08-21-2017, 06:12 PM   #8
Say what?? The digital will work with both heat and cool!!
furnace, thermostat
