12-02-2016, 10:58 AM
Furnace vs Space heater questions
Several questions here...hope ya'll can help again!
- Is the furnace in my TT propane or electric? If both, how do I switch from one to the other?
- If electric...would I be better off using the furnace or just using a 1500W space heater? I could turn down the space heater a bit to keep the watt usage a little lower. Pros/Cons of furnace vs. space heater?
1000 Thanks!
Charleston, SC
2016 Silverado 1500 LTZ
2016 Wildwood 27RKSS
12-02-2016, 11:03 AM
Insert witty title here
Your furnace is propane. It used a small amount of electricity to run the blowers and such. Personally, I would avoid using a portable space heater just for the safety factor. All kinds of house fires are started because of those things and that danger is amplified in an RV. I'm unfamiliar with your unit, but some come with a built in electric fireplace which can be used instead of your propane furnace.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
12-02-2016, 11:05 AM
Furnace is gas, it will work off the battery or when plugged in.
If your plan is to keep it warm over the winter then a space heater will work as long as the water lines have been winterized.
Space heater will be cheaper to operate.
Furnace will use a lot of gas.
12-02-2016, 11:29 AM
I believe that a "majority" of us use electric space heaters, for a number of reasons (save propane, don't like noisy furnace, etc.)
Guess we'll have to add this topic to the "Topics guaranteed to start an argument" thread. Furnace or space heater?
http://www.forestriverforums.com/for...ml#post1373950
2011 Traverse LT, 3.6L, FWD
12-02-2016, 11:33 AM
Use electric space heater(s) all the time. On cold days, evens out the highs and lows of the propane heater. On moderately cool days, saves propane and is a quiet heat source. My fireplace is electric heat and we use that on cool days too.
12-02-2016, 11:36 AM
Yep, use a small space heater as well. We keep it in the kitchen and it heats the whole unit just fine.
2017 Rockwood MiniLite 2506S
2022 F250 7.3/4.30
12-02-2016, 11:38 AM
We use space heaters almost exclusively. You'll run through a LOT of propane running the furnace- which is propane only. A few things we do to ensure safety:
1. Only use ceramic or oil filled radiator heaters. Never use anything with a coil type heating element.
2. Run heaters on low or medium- never on high unless we are awake and monitoring and just long enough to bring the temp up. This means we typically run at 600 to 900 watts. Less load on wiring and breakers, and they don't run nearly as hot. IMHO, you are being MUCH safer running 2 separate heaters on low versus 1 on high because of this. Most rigs, even if 30A, will have a circuit run for the GFCI outlets and another for standard wall outlets. Run 1 heater on each leg to split the load. Our rig has 50A service, so I actually added a dedicated circuit to a single outlet that we use for running a space heater. Therefore, I have 1 circuit for GFCI outlets, another for standard wall outlets and a third for that dedicated outlet.
3. I elevate our ceramic heaters. Typically place one on the table. If it is going to be really cold I'll run another on the kitchen cabinets. The oil filled radiator heater stays on the floor, but never gets warm enough that you can't easily keep your hand on it indefinitely. Also make sure to never cover the cords- they should always be completely exposed.
4. I always add a second smoke alarm. I like redundancy.
BTW, if you'll set your ducted A/C to fan only, it will keep the air circulating and the entire rig will stay nice and warm.
12-02-2016, 11:49 AM
I think the term 'space heater' congers up different meanings in different parts of the country.
Some folks, when they hear the words 'space heater,' immediately think propane or kerosene while others think electric.
As mentioned, the use of a small electric heater(s) will add warmth to your rig and save on the amount of propane used by the furnace. The number of heaters and their wattage will be dependent upon the type (30A-50A) shore power your unit has and what other appliances you plan to use in conjunction with them.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
12-02-2016, 12:20 PM
We use a ceramic space heater almost exclusively. It is quieter and keeps a more even heat. We generally keep it set to high but I also have a dedicated 20A power inlet that I installed so I wouldn't have to worry about overloading the trailer's 30A service main. It also comes in handy during cooling season for running a counter top convection oven or other high amperage appliance.
12-02-2016, 01:06 PM
Isn't an electric fireplace just another type of space heater?
BIRDS AREN’T REAL
12-02-2016, 01:07 PM
Yep.
12-02-2016, 01:13 PM
Left Coast
Prettier....
12-02-2016, 01:28 PM
Yes.
It's a space heater with fancy lighting!
12-02-2016, 01:31 PM
You're probably right.
But google "space heater" and click on images and 95% of what comes back is electric.
Mr. Heater's website just calls their propane heaters either "heater" or "portable heater."
12-02-2016, 01:42 PM
If I'm paying for an electric site, you can bet your last dollar that I'm going to use it. Turn on furnace and set low enough just in case the space heaters can't keep up.
Jim & Pam
2017 Ram 3500, Crew Cab Diesel Dually
2014 Hemisphere 327res
12-02-2016, 01:52 PM
Casino Camper
I use two small electric space heaters, not due to propane cost, rather, to keep the condensation down. One large electric heater can trip the GFI because it is usually shared with other outlets. It is best to keep two 1000W heaters on different circuits than one 1500W on a single circuit.
Propane is so cheap, I would not factor cost unless you are a full timer.
2016 Cherokee 264L (Rear Living)
2013 GMC Sierra Denali
12-02-2016, 01:54 PM
I have a fireplace and heat option on the front AC. Needs to get into the low 30s before the furnace is needed....
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
12-02-2016, 01:59 PM
Furnace is noisy and uses a lot of LP gas. Comments about the danger of electric space heaters are valid and have kept me alert at night when we use them, since we have a couple of cats living with us and they're not very safety conscious. I feel better now that we have a ceramic space heater with a switch that turns if off if it's tipped over. For most rigs one space heater in an circuit that has nothing else plugged in you should be fine. I also turn off the heater when we're using the toaster or coffee maker because the combination draws too much current and trips a breaker..
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
12-02-2016, 02:06 PM
Left Coast
Newer electric heaters come with a tip over safety switch...
12-02-2016, 02:08 PM
Sunseeker 2400MBW
We got this West Marine Portable Cabin Heater Model #7867500. Flat and can't tip, has good reviews from boaters and RVers. My husband had a 24ft sailboat in his past life and used this.
Model #7867500. We have only used it one weekend w/shore power and it worked well on low. The furnace is kinda loud and you get too cold and then a little too hot. Probably lack of insulation.
used to be - Full time 2016 Sunseeker 2400WS towing a 2018 Subaru Forester. 2021 we bought a house.....Still have the precious Sunseeker and tow car.
