Old 05-03-2016, 12:10 PM   #11
heater furnace forest river 2008 pop up
can anyone help me step by step to turn on my heater furnace It's a new camper to me and the instructions are vague
joweeee is offline   Reply With Quote
Old 05-03-2016, 02:20 PM   #12
Make sure propane is on, turn fan setting on thermostat to AUTO. Adjust thermostat to desired temp, should go on.
Might want to fire up stove, that will ensure you have gas in lines
Kuba is offline   Reply With Quote
Old 05-03-2016, 02:24 PM   #13
Flybob's Avatar
Light a burner on your stove and allow it to burn for 3-4 mins to clear the air from the lines. Then try the suggestions below. The fan should come on first(Safety feature), then you should hear a clicking as the furnace tries to light. After 3-4 failed attempts, the safety feature will kick in and you will have to shut the furnace off to reset the control board.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-21-2016, 08:11 AM   #14
HappyCamper77's Avatar
Turned out to be a motherboard issue. Warranty replaced.
Ontario, Canada
2014 Ram 1500
2015 Rockwood Ultralite 2905ss
Ontario, Canada
2014 Dodge Ram 1500 5.7L
HappyCamper77 is offline   Reply With Quote
furnace, light
