Old 07-12-2011, 10:22 AM   #11
The gas is off right now.
2011 Ram Laramie
2010 Rockwood 8319ss
2010 Polaris sportman 300(wife's)
2005 Polaris sportman 500HO (mine)
trailraider is offline   Reply With Quote
Old 07-12-2011, 10:56 AM   #12
I didn't see that you pulled the fuse and it stopped. What happened when you put the fuse back in? It sounds like you need to replace the furnace board to me.
Kevin
Seasonal in Wi Dells, WI
2007, Salem 4022B
kev2504 is offline   Reply With Quote
Old 07-12-2011, 11:01 AM   #13
it fires right back up when I put the fuse back in.
2011 Ram Laramie
Old 07-12-2011, 11:11 AM   #14
You could try and replace the thermostat first. The thermostat tells the board when to turn on and off. If that doesn't work it must be the board in the furnace.
Kevin
2007, Salem 4022B
Old 07-12-2011, 11:27 AM   #15
CLASS "A" Senior Member
cfsoistman's Avatar
Before replacing the t-stat, take the cover off of the t-stat and remove the white wire from the terminal. If the problem is in the t-stat it will stop running. It sounds like the board is bad in the furnace or the fan relay is welded closed.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 07-14-2011, 11:01 AM   #16
pulled the furnace apart last night. banged the side and now it works. looks like a bad relay. but I will test my luck and keep using it untill the bang method no longer fixes the issue.
2011 Ram Laramie
Old 07-14-2011, 11:34 AM   #17
DAISY BOYKIN's Avatar
Problem solved !!
Just like my ole Navy days, "GET A BIGGER HAMMER", it that doesn't fix it----------- well you know what?????? Sounds like something a "BRIT" would do!
Glad you got it solved, maybe there was was a wire touching where it should not have been, next time look a little closer look for a wire that may be grounding out under some cover ??????
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
