Old 01-26-2015, 12:44 AM   #1
furnace won't start
Hi we have a 2014 wildwood xlite and want to go winter camping but need the furnace to work. We have checked the fuses.turn on propane and yet the furnace won't start up. As get real cold here in bc we need it to work. So we are looking for help with this situation. Thank you
noddy52 is offline   Reply With Quote
Old 01-26-2015, 12:48 AM   #2
Mojojojo's Avatar
You can try cycling it on and off a few times to see if the gas lines need bleeding?
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 01-26-2015, 12:57 AM   #3
furance won't start
Hi what is recycling on and off mean. as I'm new and I'm not used to these terms. I also have to pass on these messages to my hubby. Thank you for the help
Old 01-26-2015, 01:00 AM   #4
ok hubby understands cycling. but he says the fan doesn't come on before the gas.
Old 01-26-2015, 01:06 AM   #5
Mojojojo's Avatar
Unsure of that issue it might be the circuit board is bad, does the fan make and weird noises? Our Teton had one of its fans bearings go out.so the fan would slow start then start howling. Is the burner lighting without the fan running?
Old 01-26-2015, 01:07 AM   #6
Mojojojo's Avatar
Also make and model # of said furnace might help.
Old 01-26-2015, 01:21 AM   #7
make is suburban model nt 20seq
thank you
Old 01-26-2015, 01:09 PM   #8
TimVWulp's Avatar
has the thermostat been switched to the heating mode? Not sure if you have an electronic T stat or the older one with slide bar to adjust the temp set point. There should be a manual switch on the older style T stat. The newer electronic ones have to be switched over to heating on the digital interface before the furnace fan will start this will start the ignition process. If the gas has been off for a month or more make sure to purge the air out of the gas line by starting a burner on the stove before trying to start the furnace. Good luck hope this helps.
TimVWulp is offline   Reply With Quote
Old 01-26-2015, 01:47 PM   #9
Flybob's Avatar
If this is the first time the furnace has been used for a while, you may have air in the propane lines that needs to be bled out. Try the following in order.
1. Turn on gas cook top and allow a burner to burn for a few minutes then shut off.
2. turn thermostat to the off position ( not just to a lower temp). Wait 30 seconds.
3. Try furnace again, Fan should run first then furnace will try to start.
4. If no luck try step 3 again a few times need to purge last few feet of gas lines.
5. If no luck after 3 -4 trys, go to step 2 and try 2-4 again.
There is a safety shutdown that disables the heater after a few failed attempts. You need to shut system off to reset the safety feature.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-26-2015, 10:10 PM   #10
I also talked to hubby and he said the fan didn't kick in either. We have to try some suggestions.
Old 01-26-2015, 10:24 PM   #11
Are you pluged into ac power, battery may be low
Denny in Los Lunas is offline   Reply With Quote
Old 01-26-2015, 10:53 PM   #12
Thank you yes plugged in but the batteries says its full charged
Old 01-26-2015, 10:56 PM   #13
bikendan's Avatar
if you're plugged in, the battery lights will not reflect their actual charge level.
you have to unplug from shore power and then check the battery monitor lights.
Old 01-27-2015, 12:47 PM   #14
Stg1's Avatar
If you haven't used any of the propane for the other appliances, stove, fridge,etc, Try to light the burners on the stove to allow all the air to escape from the lines. Once the burners light and burn, turn them off and try the furnace. Hope this helps.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
furnace
