Old 04-28-2012, 07:42 PM   #11
Malco's Avatar
I assume there is only one breaker or fuse for the furnace but did you check them all anyway?
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 04-28-2012, 07:43 PM   #12
Originally Posted by herk7769 View Post
Can I get a clarification on "cycles"?
So when the unit calls for heat; the blower comes on and runs for 30 seconds; then shuts down?
After i turn the thermostat switch from off to furnace...the blower comes on runs for 30sec and shuts off
cthelite is offline   Reply With Quote
Old 04-28-2012, 07:44 PM   #13
Yup!
Old 04-28-2012, 07:46 PM   #14
Malco's Avatar
Did it work ok before or were there ignition issues?
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
Old 04-28-2012, 07:51 PM   #15
Thank you
Old 04-28-2012, 07:57 PM   #16
I had one about a year ago..during that time i found that my battery was faulty (12v) the service tech told me that the funace depends on a the battery being in very good condition. HOWEVER! the ignitor was clicking then. it just would not light.
Old 04-28-2012, 08:30 PM   #17
Originally Posted by f1100turbo View Post
shut gas back off and wait for a second or two then turn gas valve back on very slowly.
Thanks. but, i already tried that...no luck
Old 04-28-2012, 08:37 PM   #18
cebaker's Avatar
I had this same problem. Make sure the camper is drawing power from the campground and not the battery. Mine had a problem from switch to one or the other. And that solve the problem. Maybe disconnect the battery.
2010 Toyota Tundra
Forest River 32vbhs
cebaker is offline   Reply With Quote
Old 04-28-2012, 09:31 PM   #19
win
win's Avatar
I had the same issue, theirs a sale switch that detects air movement from the fan, if the switch is bad, it wont allow the burner to fire.
win is offline   Reply With Quote
Old 04-28-2012, 09:53 PM   #20
Herk7769's Avatar
Originally Posted by cthelite View Post
No..There is no clicking just air blowing for about 30 seconds and it cuts off
This can be caused by lack of propane, a failed sail switch; Low Battery, dirty or corroded squirrel cage fan; or a bad circuit board.
My money is on a dirty fan. Keep an eye out for wasps when you open that puppy up.
HAM CALLSIGN - KC3FFW
