Old 04-28-2012, 01:00 PM   #1
furnace wont work
Hello fellow campers, right now as I type i'm camping.However, my furnace is not working!. Here's what it is doing.....it cycles for 30 seconds and shuts off!....there is no "electronic ignition sound"... no smell of the burner lighting..(the gas is on ) it is a "Surburban" furnace hard to see the model the furnace is installed with no labels showing anyone had this issue? haow hard is it to replace an ignitor?
cthelite is offline   Reply With Quote
Old 04-28-2012, 01:02 PM   #2
TURBS's Avatar
shut gas back off and wait for a second or two then turn gas valve back on very slowly.
Old 04-28-2012, 01:03 PM   #3
TURBS's Avatar
Also if this is the first use of the season the air may need to be purged .
by lighting surface units on stove .
Old 04-28-2012, 03:13 PM   #4
Triguy's Avatar
Turbo's advice for slowly opening the reg and bleeding is spot on. I have to bleed the lines after a few weeks of inactivity.
This manual might help you.
Edit: oops, wrong suburban manual let me see what I can find.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-28-2012, 03:23 PM   #5
Triguy's Avatar
Darn iPad
Here you go...
Scott
2012 Shamrock 233S
Old 04-28-2012, 03:55 PM   #6
Herk7769's Avatar
Can I get a clarification on "cycles"?
So when the unit calls for heat; the blower comes on and runs for 30 seconds; then shuts down?
HAM CALLSIGN - KC3FFW
Old 04-28-2012, 04:01 PM   #7
Malco's Avatar
Our old Mallard furnace used to do that if we didn't use it for a period of time.I had to do what Turbo said about lighting the stove to get the gas back to the furnace as they were very close to each other.Hope it works for you.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 04-28-2012, 07:22 PM   #8
Thanks, but.... my stove is working beautifully so is my water heater. I wanna believe that there is an air pocket preventing gas recpetion.
Old 04-28-2012, 07:27 PM   #9
Malco's Avatar
Cthelite when the blower runs can you here the ignition clicking?On ours a few seconds after the blower would start you could here the clicking until the unit would shut down after failing to light.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
Old 04-28-2012, 07:40 PM   #10
No..There is no clicking just air blowing for about 30 seconds and it cuts off
