Old 12-08-2018, 10:46 PM   #1
Furrion Access
Just saw an advert for the Furrion Access wifi system which includes antenna and an LTE Wifi router. They have several data plans. Does anyone here have one? How well does it work? Which data plan do you use? You know, all the normal questions a connected RVer would have. Thanks.
https://www.furrion.com/access
"There comes a time in every man's life, and I've seen plenty of them." Casey Stengel
"Red" my 2018 Ford Lariat F-150 4X4 W/ Max Tow pkg
"Rover" our 2018 Forest River Wildwood X-Lite 241qbxl
revbilly is offline   Reply With Quote
Old 12-08-2018, 11:42 PM   #2
Usually Confused Member
emm-dee's Avatar
Looks like they’re setting up to have the equipment installed at the factory during build. Hard to say how good it is, but I’m pretty sure it not quite as capable as aftermarket stuff (Wi-Fi Ranger, Alpha Camp Pro, etcJ.
Their data plan is horribly expensive. Five gig is $50. At that rate my bill last month would have been $3,000. But, if the hardware accepts a SIM card from AT&T or Verizon then it could be a winner.
It definitely is a very clean install that looks very good.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 12-08-2018, 11:59 PM   #3
Enjoying Life
According to its spec sheet it only supports LTE 2, 4, and 13. Looks like it will be Verizon based.
2019 Rockwood 2608BSD 2019 F250 4x4 6.2
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!” - Hunter S. Thompson, The Proud Highway: Saga of a Desperate Southern Gentleman, 1955-1967
TeachTexas is offline   Reply With Quote
Old 12-09-2018, 12:06 AM   #4
emm-dee's Avatar
That’s pretty limited capability. The later Verizon devices support bands 2/4/5/7/13/14/20/28/46/48/66.
Old 12-09-2018, 10:54 PM   #5
Enjoying Life
True, but it lets Furrion make a less expensive(to build) product with a larger profit margin.
