Old 03-06-2019, 06:09 PM   #1
Furrion TV
I have a 2018 Forester class C Motorhome
Our outside tv keeps blowing the fuse ...help
Kmneveaux is offline   Reply With Quote
Old 03-08-2019, 05:14 AM   #2
CincyGus's Avatar
Is this a 12v TV or a 120v with a standard plug? Do you truly mean fuse (12v) or do you mean circuit breaker (120v)?
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 03-08-2019, 06:51 AM   #3
Usually Confused Member
emm-dee's Avatar
OP didn’t say which model Forester but a 2018 normally has a 12V TV, outside and inside. Try disconnecting the power cord at the TV and use a multimeter to verify full voltage. Then, disconnect batteries and check for minor short to ground at the connector center pin. Then, drive around a little. If no problems found then the TV will need to be replaced.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 03-08-2019, 07:05 AM   #4
Thanks it is a 12 v tv
15 app fuse .. I think it is the TV
Old 03-08-2019, 08:00 AM   #5
Power cord is showing 13.41 v
Old 03-08-2019, 08:01 AM   #6
Thanks again
Old 03-08-2019, 08:32 AM   #7
emm-dee's Avatar
If you can find an older 12v device that has the same size plugin see if it causes the fuse action. Since your unit is a 2018 call Furion to check on warranty status.
Old 03-09-2019, 06:13 AM   #8
Thanks emm-dee I will ...
