Old 12-24-2016, 07:12 PM   #1
Forester Fred's Avatar
Furrion TV problem
I've got a 19" Furrion TV in the bedroom of my rig. It's worked flawlessly for the last 18 months. Last week while watching TV one night (hooked up to campground cable) the sound cut out. I checked the remote to make sure it wasn't muted, tried increasing the volume, shut the TV off and turned back on, nothing helped. I unplugged the TV power and plugged it back in. When the TV turned back on the sound came back on....for about 5 minutes...then cut out again. This happened two nights in a row. We got to Fort Wilderness and hooked up everything. The TV worked fine on nights 1 and 2. (cable) On night 3 the sound cut out again. I disconnected the power, made sure all the cable connections were tight, replaced the batteries in the remote and turned everything back on. TV worked great....for about 5 minutes...then the sound cut out again. Murphy's law - I'm 6 months over warranty on the TV. I sent an email to Furrion but haven't heard anything back.
Have any of you had this problem with a Furrion TV and how did you (if you did) fix it?
Oh, it's not a cable issue - the front TV worked properly the entire time.
2015 Forester 2301 - Chevy
Skip & Deb - Denmark, ME & Delray Beach, FL
Forester Fred is offline   Reply With Quote
Old 12-25-2016, 08:47 AM   #2
By the time you figure out the problem with the TV as it is not just a simple connection problem, and the cost to have it repaired (if it can be), you could have a new one. Not to be trivial with money, but at $150 or less for a new "good" 19" TV, why hassle with the old one?
Mark
Wileykid is online now   Reply With Quote
Old 12-25-2016, 09:59 AM   #3
northstar1960's Avatar
hate to tell you this but furrion is about the worst /cheapest TV a dime can buy . just replace it with something better problem solved .
northstar1960 is offline   Reply With Quote
Old 12-25-2016, 10:55 AM   #4
Hook up a DVD player and see what happens.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 12-26-2016, 02:40 AM   #5
Mr Havercamp's Avatar
Have to agree with this. RV manufacturers are not using Furrion electronics because they are the best. Furrion has an agreement / partnership with Lippert. Birds of a feather.
2017 Roo 23WS
2015 GMC Sierra 2500HD 6.0 DCLB Z71
Mr Havercamp is offline   Reply With Quote
Old 12-26-2016, 09:30 AM   #6
Learjet's Avatar
you could try the headphone jack when it cuts out, see if sound is still present there.
-2013 Ford F250 XLT 2wd Crew Cab 6.2 with 3.73
-2015 Wildcat 317RL
-B&W Patriot 18k, MorRyde, Timbrens
Learjet is offline   Reply With Quote
Old 12-26-2016, 05:02 PM   #7
Thanks for the input. I'll try the headphone jack and CD/DVD ideas. If they don't work then I'll go shopping.
Old 01-11-2017, 03:13 AM   #8
Ekw4156's Avatar
My 40 inch furrion does the same think, I just tap the bottom right side of the TV and it returns.
Ekw4156 is offline   Reply With Quote
Old 01-11-2017, 03:20 AM   #9
Perhaps a good swift kick to the bottom right side may fix it permanently? Furrion......
2017 Roo 23WS
Old 01-11-2017, 04:00 AM   #10
World Wide Wanderer
wahoonc's Avatar
Furrion is an ancient Chinese word for cheap...
I am willing to bet that something inside is overheating or loose. Easiest thing to do is get another TV, I would buy something besides a Furrion though.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
