Old 07-23-2015, 05:38 PM   #1
Fuse?
We have a 2005 Lexington motor home. We turned on the generator and had the air conditioner going. I then turned on the microwave and after 1 min they both stopped working. Checked the fuses and they are fine. Any suggestions?
ethompson is offline   Reply With Quote
Old 07-23-2015, 06:28 PM   #2
Did you also check your breakers?? Both are AC appliances so the problem may be with a breaker. Do your AC plug outlets work OK??
bruceatlam is offline   Reply With Quote
Old 07-23-2015, 07:56 PM   #3
Jim Schings's Avatar
More than likely it is the breaker ON the GenSet, It is sometimes hidden off to the side a bit. Looks a bit like a normal wall switch.
Jim Schings is offline   Reply With Quote
Old 07-23-2015, 08:59 PM   #4
bikendan's Avatar
Microwave and a/c are 110v AC and use breakers, not fuses.
Old 07-24-2015, 06:15 AM   #5
Thanks for the tips. We are new to this RV and didn't get the best instructions. I will pass this on to my husband and post if this works. I appreciate the help.
fuse
