Old 04-23-2016, 11:05 AM   #1
Fuzzy TV!
Out on our first trip of the season, the campground has cable. Both my living and bedroom TV's scan and find all the channels, the sound is good but the picture is unwatchable because it's too snowy! Luckily we can get some over the air channels and they work fine! And yes, I have the booster off when in cable mode. Any suggestions on what's causing the bad picture in cable mode? I've also checked all the connections that I can find and made sure they were tight.
atcla is offline   Reply With Quote
Old 04-23-2016, 06:03 PM   #2
Run a cable from the post to the tv, that should tell you if it is their's or in your trailer.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 04-23-2016, 06:29 PM   #3
Land of the Midnightsun
jjSpeedwagon's Avatar
Bad cable conections. Had to cut off and replace couple of mine. Trick is finding them
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 04-23-2016, 10:52 PM   #4
Thank you Dwilcox and jjSpeedwagon! I ran the cable directly to the tv and works great, now I guess the fun part is finding the bad connector or cable in the trailer!
Old 04-23-2016, 11:08 PM   #5
Dale & Karen
Old 04-25-2016, 06:14 PM   #6
Just a quick comment make sure your antenna booster is not on. The tv will scan ok but picture is terrible. Been there done that.
Rich5117 is offline   Reply With Quote
Old 04-25-2016, 06:31 PM   #7
nomad297's Avatar
This is what I'm thinking the problem is.
Bruce
Old 04-25-2016, 07:32 PM   #8
Thank you Rich5117 and Bruce! The booster was off, been there done that too! 😃 I'm back home now and will be checking all the cables and connections I can find! I'll check back in if and when I can find anything!
