I'll just keep a couple batteries handy. From TST: Sensor Low Ba ery Alert
The sensor low ba ery indicator will display when the CR1632 sensor ba ery is at the end of its life. The re a ected will ash along with the pressure and temperature read-out and the low ba ery symbol and (!) on the le side of the display. Replace with a new ba ery as soon as possible.
NOTE: This low ba ery alert will display for only a short me un l the ba ery is exhausted. If you do not have the display on o en, the indicator signal will be sent but not shown on the display, since it was o . If your sensor is not repor ng to the display, check the ba ery voltage. If it is below 2.75 volts (normally 3+ volts), you may have to change the sensor ba ery.
I don't know why the T in battery didn't come out in this cut and paste. BTW, I've had horrible luck ordering button cells on Amazon, they have frequently been low voltage, like they are very old.
Yes, I drink the water!
