Old 02-09-2019, 07:31 PM   #1
Mr. Dan's Avatar
Gaping opening in Furnace
Originally Posted by Larry-NC View Post
I had this exact situation. It would even light if I left the plenum cover (sheet metal that covers the heat exchanger) open. If I installed that cover, it would not light. It turned out to be a failed propane regulator at the tanks.
More detail:
The first thing the Suburban manual tells you to check is the propane pressure at the furnace. I ignored that because:
  1. The range worked okay/
  2. The water heater worked okay.
  3. I didn't have a gauge to measure 11" water column (0.4 psi)
After wasting hours of time trying other things, I finally spent 60 minutes building a gauge (picture on request) and discovered the regulator was out of wack. Attempting to adjust it caused a strong smell of propane, telling me three things:
  1. The regulator diaphragm had developed a hole.
  2. The life of a regulator really is ten years, just as everyone tells you.
  3. DW probably should have put a new shroud on the regulator and tanks when the old one fell apart.
Everything worked fine with a new regulator.
Larry
Moved from another thread to cure my high-jack!
Larry, in the pic I'm attaching, is the hole in my furnace where you're saying my plenum cover goes? Last fall, we were running our furnace (which we rarely do) and DW told me warm air was coming OUT of big air return grate. I found this hole open - no cover ever on it since we've owned it. I guess I should just get a piece of sheet metal and attach it to cover that hole. Right?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Old 02-09-2019, 08:03 PM   #2
Plenum cover
Mr. Dan,
The plenum is the big box that surrounds the firebox (flame is inside the firebox). The plenum cover is that rectangular piece of sheet metal (maybe 8" x 24") on the front of the furnace. There's a baffle (partition) near the back which separates the return area and blowers from the plenum/heat exchanger. You have to take the plenum cover off to slide out the firebox/blowers/controller assembly.
The plenum itself is like an electrical junction box in that it has knockouts on the front and sides and bottom where ducts could be attached. Holes in the back are where air going through the return air grate enters the blower, to be blown into the plenum.
I couldn't make sense of your photo, but your description sounds like the installer punched out a knockout he never used. If that's the case, you would close it off. Duct tape for a temporary fix.
For something more permanent, if you have space you could pop-rivet a piece of sheet metal across the hole, working from the outside. If you don't have working room on the outside, you could take the firebox/blowers/controller assembly out and pop-rivet a piece of sheet metal to cover the hole from the inside. It's not as big a job as it sounds.
EDIT
Looking at the photo again, I realized you were talking about the perforated area at the back part of the case. (Actually that back part is the intake area. The plenum is the unpierced part forward of the grating.) That's where return air goes in. Don't restrict it. In fact the Suburban Installation manual dictates how many square inches must be open. If you run the furnace and hold a dollar bill over that grating, you will find that it's sucked to the grating, not blown away. But while you are in there, you might be able to see where the warm air is coming from.
Larry
Larry-NC is offline   Reply With Quote
Old 02-09-2019, 08:16 PM   #3
Mr. Dan's Avatar
Mr. Dan,
Larry
Thanks. I may make a better pic later. In this pic I can see unused round duct punch outs on the left side. It’s the rectangular opening in the top/horizontal panel of the case and just past the front/vertical edge of the furnace case that surprised me. I assume what I see in that rectangular opening is the heat exchanger. I was surprised to see such a large un-ducted opening in the case.
Old 02-09-2019, 08:19 PM   #4
Mr. Dan's Avatar
No, I wasn’t talking about the “perforated” grate. I knew that was the intake. On my side of the input grate is a printed diagram, etc., and the opening I’m talking about is closer to the camera that the printed label.
Old 02-09-2019, 08:40 PM   #5
Oh, that one!
Oh, still don't see it, but if it's forward, it should be plugged. Otherwise, some heat could be sucked right back in and re-heated. And if it's plugged you will get more air volume at the vents.
Larry
Old 02-09-2019, 08:42 PM   #6
Mr. Dan's Avatar
Larry
Did you click on the pic so you can see all of it?
Old 02-10-2019, 06:01 PM   #7
onetonford's Avatar
what is off to the right it looks like it may go on top is that the duct work or something else.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 02-10-2019, 06:15 PM   #8
Mr. Dan's Avatar
No... good question, however. What you see is foil-wrapped packaging I used for insulation to keep heat from the furnace away from my PI EMS box further off to the right.
Larry-NC and I had a PM exchange later and Larry thinks the hole SHOULD BE covered with an inspection panel which we could see drawn in stick-figure furnace manuals. That said, I don't remember seeing the gaping hole when I installed the EMS so I will go out soon and look in the area to see if I can find a stray metal panel. I will fix it before my next trip because the opening causes two problems: 1. reduced flow to downstream vents and 2. heated air being drawn into the intake grate further back and reheated instead of being sent downstream.
I'll report back.
Old 02-11-2019, 04:36 PM   #9
Mr. Dan's Avatar
Three more pics. I fished around in this cavern feeling for this cover in case it just jiggled off but no luck.
ID:	196595Click image for larger version
ID:	196596Click image for larger version
Old 02-11-2019, 04:48 PM   #10
Dan, that serpentine shaped thing inside is your heat exchanger. Seems there should be a plate/cover over the big square hole. Do you have a manual for this furnace?
2011 Traverse LT, 3.6L, FWD
