Old 11-22-2018, 10:56 AM   #1
Generator Issue
I have a 2014 Sunseeker and just tried the Generator for the first time. I assumed if that was running the outlets inside and outside would have power. I didn't so I am wondering what might be the cause of this.
I am also having some issues with starting the Chevrolet that might be part of the problem. It will start about 19 our of 20 tries with the first try but when it fails, I get nothing, no click, no start etc.
What kind of electrical testers would you suggest do start learning diagnostics for a beginner ?
Thanks in advance for any assistance you might give.
Gary Menia
garymenia is offline   Reply With Quote
Old 11-22-2018, 10:59 AM   #2
A32Deuce's Avatar
There is a circuit breaker on the generator itself. Check that as it sounds like it tripped.
A32Deuce is online now   Reply With Quote
Old 11-22-2018, 10:59 AM   #3
Gary Menia
Do you need to plug your cord into an outlet for the generator or do you have a transfer switch? since you have no power when genny is running i would look at the 2 items mentioned above
MR.M is offline   Reply With Quote
Old 11-22-2018, 11:02 AM   #4
A32Deuce's Avatar
My 2012 has a built in transfer switch, so I would thinks 2014 would also. I don't think the SunSeekers went backwards.
Old 11-22-2018, 11:07 AM   #5
If there is a transfer switch I don't know where it is. I will dig out the manual and study up. There is no visible outlet on the generator so I assumed it automatically fed the outlets.
Lots to learn. Thanks all
Gary
Old 11-22-2018, 12:15 PM   #6
A32Deuce's Avatar
It is an automatic transfer switch. You don't have to do anything with it unless the breaker on the generator is not tripped. Check the generator breaker first. Mine has tripped on start up a couple of times in 6 years.
Old 11-22-2018, 01:00 PM   #7
It's the RV industry anything is possible when it comes to them lining their pockets and c heaping up their product is fist on the lists
Old 11-22-2018, 01:01 PM   #8
Gary
Follow your shore p[ower wire it shoule lead into a transfer switch if you have one . if not there will be an outlet in the same storage as the shore power cord
Old 11-22-2018, 01:52 PM   #9
A32Deuce's Avatar
You did not read what I posted about the SunSeeker.
Old 11-22-2018, 02:14 PM   #10
Sure did . OP didn't know where or if there was a transfer switch and i gave him good advice on how to find it . follow the shore power cord . maybe you didn't read what i posted ?
generator
