Old 10-18-2013, 02:07 PM   #1
Genesis 2.0
Cannot get my Konka tv to play through the Genesis 2.0 surround sound.I have tried patch cords from the back of the unit & the correct cord from the tv to the front of the unit. What am I missing? Ted
tbanner is offline   Reply With Quote
Old 10-19-2013, 10:56 AM   #2
Have you gone through the setup menu on the Genesis controller to select the correct input? Just checking.
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 10-20-2013, 08:01 PM   #3
Paul & Sheri
pwb01's Avatar
I have the unit disconnected and winterized now so I can't check but I believe the tv is aux 1. Aux 2 on mine is xm radio. When I play a dvd through the Genesis, the sound is just there with the dvd running without setting any aux input.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 10-22-2013, 10:02 PM   #4
TV connects to the Aux 1 input typically from a headphone jack on the side of the TV. Make sure you are selecting aux 1 and not AU 1 which is a different input. Make sure the volume on the TV is turned up as this might be part of the puzzle your missing. After you get it working, Add a small cube speaker (put mine under the dinette table) as the sub woofer. Connects to the Green and Green-Black wires on the speaker wire plug. You will notice a huge difference in the audio quality.
Netcomdude is offline   Reply With Quote
