Genesis 2.0, minilite 1905
Took our new Minilite on the first trip this weekend, everything seemed ok. Only niggle so far is that I can't figure out how to get the video signal from the Genesis unit to the TV. The only video connections are mounted on a plate under the Genesis, both are coax. One is labeled Aux/Sat and the other is labeled TV. I connected to the campground's cable through the TV connection. However, when playing a DVD in the Genesis unit, the TV wouldn't recognize a video signal regardless of which coax I used. I can hear the audio, so I know the DVD is playing.
I think there should be another video cable; I've never run anything other than cable over the coax. Any suggestions? I can post a pic of the setup later if it helps. The techs at the dealer weren't very knowledgable about the AV system. The Genesis manual wasn't much help either.
Thanks,
Mark
