Old 08-13-2014, 05:44 AM   #1
toylover's Avatar
Genesis 3.0 and television
The radio works fine however when I try to play a DVD there is sound and no picture. Also I cannot get the tv to work on the surround sound on the radio. Any thoughts.
toylover is offline   Reply With Quote
Old 08-13-2014, 07:21 AM   #2
iowaborn's Avatar
Send a message via AIM to iowaborn
Did the tv/dvd work before? If it did and there were no modifications made, check the connections. Try hooking the tv up to a different player if one is available, if that checks out, it may be a defective Genesis unit, they have numerous discussions in the forum of people having problems. Mine was replaced at the Goshen rally due to the dvd player problems.
2013 F-250 CrewCab 6.7 PowerStroke 4X4
2017 Silverback 33RK
iowaborn is offline   Reply With Quote
Old 08-13-2014, 07:34 AM   #3
Herk7769's Avatar
How is the Gen 3 connected to the TV?
If you have an HDMI input on the TV, run an HDMI wire from back (not front) of the Gen 3 to the HDMI input on the TV.
As to sound from the TV to the Gen 3
Do you have an audio output on the TV?
If so, analog (Red and White RCA "phono" plugs) or digital (Orange/black RCA or TosLink Fiber Optic)?
Remember to get surround OUT of the TV you will need to use the digital outputs if available and go IN to the Gen 3 through the rear digital inputs. Make sure you select which input on the Gen 3 you connected to in the audio setup (can choose COAX or TosLink there).
ID:	60403   Click image for larger version
ID:	60404   Click image for larger version
Name:	ZX-800 connections.jpg
HAM CALLSIGN - KC3FFW
television
