Old 08-10-2014, 07:49 PM   #1
Cool Genesis 3.0 wont come on
I have been using my genesis 3.0 for 2 years now no real issues. Just was out camping 2 weeks ago and it was working. Went camping this weekend and it will not come on. The power button lights up but when you press it nothing happened. Checked fuses in the power panel all ok. Does anyone know if there is a inline fuses behind the unit or any suggestions thanks.
Rabidd is offline   Reply With Quote
Old 08-10-2014, 07:57 PM   #2
dannyabear's Avatar
Is 1 or more 'speaker' buttons pushed in for sound?
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 08-10-2014, 08:05 PM   #3
I checked every button on the panel but I can recheck tomorrow
Old 08-11-2014, 04:19 PM   #4
Checked all speaker buttons and all others doesn't come on.
Old 08-12-2014, 04:21 PM   #5
brownie289's Avatar
Mine acted similar.
Removed the unit, unplugged the wire harness.
Light stayed on for about 3 sec then went out.
Plugged back in an now works.....
Db
2015-26days, 2014-32days,
2013-33days, 2012-30days
brownie289 is offline   Reply With Quote
Old 08-12-2014, 04:44 PM   #6
2 Old Fossils's Avatar
If the power button is lit, the fuse behind it is OK.
2 Old Fossils is offline   Reply With Quote
Old 08-12-2014, 04:47 PM   #7
brownie289's Avatar
Mine the fuse was fine but needed all power removed from the unit,
Old 08-12-2014, 09:31 PM   #8
During walk through for pdi on the used 2012 Wildcat we bought a few weeks ago, had same issue. Tech said someone left some lights on and forgot to switch batteries off so batteries died. Tech pulled unit out, pulled power and plugged back in to restore power. Worked fine after that and since. Tech said low voltage can cause the behavior and a power reboot normally will straighten it out
Mkccowboy is offline   Reply With Quote
Old 08-12-2014, 09:48 PM   #9
B and B's Avatar
You can pull the fuse at the convertor as well instead of pulling the unit out. Faceplates can break easy!
B and B
