Old 10-16-2015, 10:20 AM   #1
Genesis GT 3.0
Rockwood camper with entertainment system Genesis GT 3.0. When playing DVD the video doesn't work. Everything else with the system works fine. We get audio when playing DVD, just no picture. Had several "techie" people to check it but no one can fix it. Tried to get the black rim off from around the system in the wall but wasn't sure exactly how and didn't want to break it. From there I am hoping to check the fuses I have read some talk about on this forum and the connections. Any input is appreciated.
Thanks, Sharen
Sharen is offline   Reply With Quote
Old 10-16-2015, 10:31 AM   #2
Witch Doctor's Avatar
You just pull the black ring off it snaps on. Then I think there are either 4 or 6 screws that have to come out then you can get to the connections after you pull the unit straight out. I think the video wire is the yellow plug that you will see
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-16-2015, 01:05 PM   #3
gljurczyk thanks. On the way to campground now. Plan on hopefully fixing it. Have you or anyone heard of the video being a problem with these?
Old 10-16-2015, 02:49 PM   #4
Yes but most of the time it's because of the connection between the unit and TV. They have discontinued that system, and switched to the IRV units. You can forget any replacement for that unit. Mostly it's a wire problem. Do you have the booklet that came with the unit, that will show you what has to be hooked to what?
Coachmen M/H
Concord
2018 / 300 DSC
