Old 02-04-2017, 12:16 PM   #1
ed9
Genesis Stereo
Hi. I have a 2013 Rockwood SIG Lite 5th wheel with the Genesis 3.0. Recently it stopped powering on. Checked fuse on equipment, ok. Is there another fuse for it in maybe in battery compartment?
Also, what do you recommend for a replacement to fit in the space where the Genesis sits underneath the TV cabinet? Thanks everyone.
ed9 is offline   Reply With Quote
Old 02-04-2017, 01:33 PM   #2
Do a search on the internet. They like so many others mfgs install are basically junk. Places like Crutchfield.com offer a lot of decent, some high end replacements.
donniedu is offline   Reply With Quote
Old 02-04-2017, 02:13 PM   #3
GreenImp's Avatar
Send a message via MSN to GreenImp
Agree that the Genesis is junk. I replaced mine with a home receiver and consider it one of the best "mods" I have made to the RV.
I assume that all of your other 12v devices are working (lights, water pump, etc.)?
Do you have access to a 12v tester of any sort (multimeter, test light, etc.)? Checking for 12v at the fuse seems a lot easier to me than trying to track down other inline fuses/circuit breakers etc. The 12v circuit likely is protected at the battery and or the converter, but there would almost certainly be many more items on that same circuit breaker/fuse (lights, etc.). In a pinch, you can take any 12v device and use it to test for voltage at the stereos fuse.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 02-05-2017, 12:53 PM   #4
ed9
Thanks both of you. I'm thinking replacing with home stereo. But I like having DC .
Old 02-05-2017, 01:35 PM   #5
dea49's Avatar
They make some pretty nice 12v car radios that have Bluetooth, DVD and many other amenities. You could just create a cover and insert the radio into that.
2007 Rockwood UltraLite 2603
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
dea49 is offline   Reply With Quote
Old 02-05-2017, 03:51 PM   #6
ed9
I thought about that and the space . Will look into it.
Thanks.
Old 02-06-2017, 08:24 AM   #7
When you get behind your Genesis 3.0 you will find a huge cluster of wires going to all the speakers, etc. It will require a lot of patience to wire in another unit. As mentioned above, Crutchfield offers a "plug 'n play" replacement but it is $600 if memory serves and it may not be any better quality than the Genesis unit.
There are several good quality car radios that have most of the same features as the genesis but wiring them in will take carpentry and electronics ability. One feature we require is weather band and that will knock out most of the contenders.
Just my $0.02
N. Brevard County, Florida
2010 Lexington 255 GTS
2000 Jeep Cherokee Toad
dontay is offline   Reply With Quote
Old 02-06-2017, 09:43 AM   #8
Herk7769's Avatar
There should be at least one inline fuse behind the radio on the red wire, and one behind or IN the Power Center (where the circuit breakers and main fuses are). The Power Center fuse may also provide power to the roof antenna power switch wall plate, so look to see if the light comes on when you toggle between roof and cable.
The fuse behind the power center will be in a blade type fuse holder.
HAM CALLSIGN - KC3FFW
Old 02-06-2017, 10:47 AM   #9
ed9
I only saw one fuse back of radio where red power wire is and good. Are you talking about the radio fuse in the power converter? Checked that and good. Thanks. Let me know.
Old 02-06-2017, 11:18 AM   #10
Herk7769's Avatar
If you have a radio fuse that is labeled; then yes.
Mine is on a "pigtail" behind the unit.
Have you tried a "hard reset"?
Name:	RESET ZX-550 001.jpg
ID:	129299   Click image for larger version
