Old 03-08-2014, 05:48 PM   #1
Cool Georgetown 340 furnace not working
I have a Georgetown 340 with a Suburban furnace that stopped lighting. A tech looked at it and told me the module needs to be replaced. The furnace is located under the refrigerator. My questions are: 1. Can I get to the module without removing the furnace? 2. If I have to remove it, can it be removed without taking out the refrigerator? (My RV is in storage right now and I can't get to it.) Thanksin advance.
hapecmpr is offline   Reply With Quote
Old 03-09-2014, 11:15 AM   #2
Don't know about your specific model but usually if you remove the propane connection and the wire connections there are only a couple of screws holding the furnace in place. The tech was probably referring to the circuit board which is easy to access once the furnace is removed.
Note the circuit board may not be the problem. It is easy to bench check.
cadman99 is offline   Reply With Quote
furnace, georgetown
