Old 03-28-2015, 10:11 AM   #1
GFCI outlets to working on Rockwook 2907SS
First day in new trailer. Where is the reset for the FCI outlets. None are working. No breakers are tripped in breaker box. Wear eddy camping but running off 2 6v so should be fine. Lights, water pump, etc... Are all working
Thanks for your help
Cmprobert is offline   Reply With Quote
Old 03-28-2015, 10:14 AM   #2
StoneyG's Avatar
There should be a reset button in the middle of one of the outlets, maybe in the bathroom
StoneyG is offline   Reply With Quote
Old 03-28-2015, 10:44 AM   #3
caper's Avatar
Are you plugged into 120v?
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-28-2015, 10:55 AM   #4
If you are running strictly off of batteries, none of the 110V will work.
Old 03-28-2015, 11:17 AM   #5
TURBS's Avatar
As said only 12v items will work.
If you want the outlets to work "110" you have to plug into shore power or a generator.
Turbs
Old 03-28-2015, 12:44 PM   #6
You need to either be hooked up via a cord to shore 120v power, on a generator, or use an inverter which converts 12v battery to 120v and must be wired in properly to run the 120v outlets.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 03-28-2015, 12:49 PM   #7
vinmaker's Avatar
X2 about being hooked up to shore power.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 03-29-2015, 10:15 AM   #8
Thanks everyone, guess I'll need to get an inverter! My last RV had one, and didn't even think of that
electrical
