First day in new trailer. Where is the reset for the FCI outlets. None are working. No breakers are tripped in breaker box. Wear eddy camping but running off 2 6v so should be fine. Lights, water pump, etc... Are all working
Thanks for your help
You need to either be hooked up via a cord to shore 120v power, on a generator, or use an inverter which converts 12v battery to 120v and must be wired in properly to run the 120v outlets.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
