08-19-2019, 09:50 PM
GFCI plugs
I bought a small 10 in fan to use at night in bedroom, I unpacked it and plugged it into kitchen GFCI plug to test it, I turned it on to hi, then medium, then low all worked well, then I turned it to hi and it quit, thinking I’d turned it a notch to much to off but realized the plug was dead, I soon realized the GFCI plug in bathroom and outside are all dead, I checked the breaker and it appeared to be on but flipped off and back on, all plugs are still dead,
I couldn’t delete this whole message but the plug in the restroom has a reset button I couldn’t see because of a night light , I knew the other 2 plugs didn’t have a reset so I thought a fuse controlled each of them, the reset button restored all plugs . Lesson learned !
08-19-2019, 10:44 PM
There may be another GFI outlet that's tripped.
08-19-2019, 11:13 PM
I'm glad you've solved your own problem. Here's another lesson to be learned. GFCI outlets and their circuitry are 120v AC circuits. They are associated with breakers. Fuses are for 12v DC circuits. GFCI circuits are not affected by fuses.
08-19-2019, 11:14 PM
Dan, the OP edited his post with his solution.
08-20-2019, 12:50 AM
Must have been after I posted.
08-20-2019, 07:13 AM
No, I didnt realize that! My fuse box listed a 15 amp fuse for kitchen and 1 for bath and I assumed it was plugs, it must the the lights though after reading your reply, thank you!
08-20-2019, 07:17 AM
Thank you for reply! All three plugs went down but only the bathroom plug has a reset button, I didn’t even see it because of a night light plugged in. I had already decide the coffee would be made in living room this morning!!! Lol
08-20-2019, 07:18 AM
Take a look at the 12V side of life in the library. ( green bar).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-20-2019, 08:12 AM
Your 'fuse box' isn't really a fuse box for the items that run off 120v.
They are breakers that trip when there is an issue. Houses and r/vs don't use fuses for 120v anymore (used to years ago) but folks still call the power distribution box a 'fuse box'.
Anyway the breakers that control the 120v items (including the GFCIs) are lever type breakers that you must flip the lever to reset. I suspect what you seen labeled as kitchen and bath are in fact 120v breakers.
Your power distribution box also has 12v fuses and they must be replaced if they are burned out.
120v breaker...
12v fuses...
One more thing... the reset button you pushed on the GFCI will only reset if the outlet has power coming to it. Most have a little green indicator light on the plug indicating power (some don't) so if the little LED is green and lit up, it will reset.
If it won't reset, you'll likely need to find the breaker labeled GFCI in the power distribution box and reset it before you'll be able to reset the GFCI button at the plug itself.
08-20-2019, 08:58 AM
120v breaker...
12v fuses...
I copied this and put it in my notes!
08-20-2019, 10:03 AM
FYI, I've come onto a couple of fans that will pop the GFI whenever they are turned off. I assume the rotating fan is working as a generator, putting unexpected electricity into the circuit. I have continued to use them with no other problems. Once you know the problem, it is an easy fix to reset the GFI.
2018 Shadow Cruiser 265RLS
2018 Chevy Silverado 1500 with 5.3 max tow package
Shiawassee County, Michigan
08-20-2019, 10:13 AM
Had a friend of mine go through this same thing last weekend. When he told me the issue, I told him to look for the GFCI plug and reset it. Problem solved. Got a glass of Scotch out of that [emoji1634]
08-20-2019, 10:20 AM
This can be a problem with fans that have digital speed controls and digital motors.
TST Tire Monitors
2 100W solar panels
08-20-2019, 10:50 AM
X2
I've seen fans kick the GFCI when turning off the fan.
I never could say if it was an overly sensitive GFCI or a condition of the fan control. Didn't do it every time so none the less, we just reset the GFCI and all was well.
08-20-2019, 10:58 AM
If your GFCI keeps tripping for things that shouldn't trip it, replace it. Some are too sensitive, and others just seem to weaken with age. Quality might have something to do with it also. I've replaced several in my RVs and my house. No more unnecessary tripping and resetting.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
