Old 03-26-2019, 01:36 PM   #1
Got tired of guessing which way to point antenna before scan
When I got ready to watch some TV in the evening when camping without cable hookup I got frustrated by long scan times and few channels showing up.
To alleviate this I installed one of these this weekend:
https://www.amazon.com/Winegard-RFL-...96496009&psc=1
Now I merely press select button (which turns it on by changing from park cable mode) and start a scan. The scan will locate the strongest signal in the area and I can adjust gain to help it reach out farther. Once a channel is revealed I can re-orient the antenna for max signal strength. If signal strength is high I can dial down gain and peak signal again by turning antenna. Only then do I do a channel scan on my TV.
If there is a specific channel I want after looking at an online map of OTA tv stations in the area I can select that channel and then dial in max strength for that channel alone. Comes in handy if you're watching a channel that is delivering an unsteady picture, often looking like a checkerboard. Merely adjust gain and antenna direction for max signal strength.
I know, it's more expensive than the signal strength meters sold for orientation satellite dishes but I find that it also does more. My house is in a location behind a hill from most of the area's TV towers. First scan after installing it yielded 10 more stations than before when using the original "on/off" amplifier. This is with the low profile "Millenium Falcon" antenna (Rayzar ZI) that came with the trailer, not a "bat-wing". I kind of like the low profile one. Less chance of driving off with it still up
According to Winegard it works with all Sensar antenna's including the Rayzar's (Millenium - Falcon typs).
Anyone else using this Amplifier/Signal Strength Meter?
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 03-26-2019, 02:39 PM   #2
A32Deuce's Avatar
I use an app on my phone that shows where they are, how far, and if you can/cannot receive the signal.
A32Deuce is online now   Reply With Quote
Old 03-26-2019, 02:42 PM   #3
kfd82's Avatar
Which app is it? I have the TV Towers app and it really doesnt work that well in my experience.
kfd82 is offline   Reply With Quote
Old 03-26-2019, 02:46 PM   #4
A32Deuce's Avatar
DTV antenna. Free and works pretty good. Use it every place we stay that does not have cable, which most don't. I like to keep track of local news/weather when out in the RV.
Old 03-26-2019, 02:55 PM   #5
Trailer Park Supervisor
NJKris's Avatar
Great tip Deuce. Will install it.
NJKris is offline   Reply With Quote
Old 03-26-2019, 03:17 PM   #6
Head Rambler
We have one of those and it works well. I won't say it's the best investment we've made, but it sure cuts down on the tv setup time.
Gotta go campin!
Old 03-26-2019, 03:24 PM   #7
bikendan's Avatar
I've been using TV Antenna Helper for years. Just downloaded Winegard Tower Finder but haven't used it.
Way easier and cheaper than buying and installing the Sensor Pro.
Equalizer WDH
Old 03-26-2019, 03:35 PM   #8
bubbles's Avatar
Just step outside and see which direction everyone else's antenna is pointing.
Old 03-26-2019, 04:26 PM   #9
I was using the Winegard app for quite a while but it didn't really help in telling what signal strength I'd get or help me "peak" the signal by re-orienting the antenna or increasing the gain. You also need a compass with "Tower Finder". The top of your phone screen will always be North but do you know where North really is where you are?
As for just looking which direction the antenna's are pointed, what do you do when none are pointed the same direction or almost everyone else has a satellite "dome"?
2004 Nissan Titan
Old 03-26-2019, 04:46 PM   #10
A32Deuce's Avatar
There is a compass app for your phone.
antenna, tire
