Let's say that you go to a campground that is at least five (5) years old. A lot of campers, me especially, will turn all the breakers within a box to OFF before we connect anything. Then after making our connection we turn the breakers to ON. Circuit breakers are not designed to be switches, just protection from electrical loads drawing more amps than the circuit is designed for. Flipping the breakers OFF and ON will cause the breaker to have a shortened life. I have been taught that circuit breakers will/do become weaker the more they are flipped On and/or OFF. You could have been operating on a weak 30 amp breaker. I have had to ask one cg to change out a 30 amp breaker once and that did resolve my problem at that time. As stated in one post, figure a 15,00 BTU RV air conditioner unit will require 20 amps to start and then 12-15 amps to run. Add in 8-10 amps for the fridge, 6-8 amps for an electric water heater (these numbers vary with manufacturers and appliance age) and you will understand how a single 30 amp breaker reacts to the load of a camper. Just this weekend we went camping with two other campers/friends. It was hot, the temp in my truck showed 96* when we pulled into the campground. One of the campers had a short shore power cord so he hooked up with a 14 ga. 25 foot cord he had with him. After about 4 hours his unit went dark. The male end of his cord, plugged into the campground 30 amp receptacle, had actually melted and shorted out. The outer insulation of his cord had signs of high heat a good 24" back from the male end. We went to a local Wally World and bought a 25 foor 10 ga. RV type cord for him and he made it through the rest of the weekend. Some of the older readers may even remember the "Green Acres" method of using electrical appliances.
