04-21-2015, 06:30 PM
Grill won't light
Trying to use the outdoor gril for the first time. Hose is hooked up LP is on but it won't light. Any suggestions?
04-21-2015, 06:38 PM
Make sure both valves are open and try lighting with a butane striker.
04-21-2015, 09:13 PM
Tried it with a lighter no luck.
04-21-2015, 10:08 PM
Is propane flowing? On mine I eventually found the 90 degree black pipe fitting was cast solid, thus no flow. This was after replacing the burner and gas valve on the grill under warranty.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
04-21-2015, 10:33 PM
Does your grill have a regulator on it? There's a regulator on your RV propane system and an additional regulator on the grill won't have enough flow to work.
04-22-2015, 05:46 AM
There may be an LP shut off valve where the quick connect hose is. Just under the trailer.
Ontario, Canada
2014 Dodge Ram 1500 5.7
2015 Rockwood Ultralite 2905ss
Ontario, Canada
2014 Dodge Ram 1500 5.7L
04-22-2015, 09:58 AM
Might help if you mentioned what model RV you have
04-22-2015, 10:55 AM
There is a shut off valve where you plug in gas line to camper. Valve handle should point to you.
This assumes you are not getting gas . If you are getting gas the spark ignition is to blame, use a match to light.
04-22-2015, 11:53 AM
Left Coast
When I bought mine, I went to a gas fireplace store and they did the required pluming to be able to use the trailers ouick connect lash-up. One is a low pressure system and the other a high pressure deal.
04-23-2015, 06:54 AM
Got it working now.
04-23-2015, 07:12 AM
Got it working now.
And what was the issue?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
04-23-2015, 10:29 AM
X2
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
04-23-2015, 10:50 AM
Left Coast
TURBS
4 16oz, sandwitch, dunno, let the night crew fix it.
04-23-2015, 07:01 PM
Got it working now.
What was the problem?
Ontario, Canada
Ontario, Canada
04-23-2015, 07:46 PM
Left Coast
Ontario, Canada
Were on the ignore list.
04-24-2015, 07:23 AM
Lol
Ontario, Canada
Ontario, Canada
04-26-2015, 06:36 PM
Had the same problem with my grill on my Windjammer, discovered it was operator error. Found the gas shut off in line with the quick disconnect. It really works pretty good once I turned the gas on.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
