Old 10-11-2011, 07:02 AM   #11
excream: our minilite 2011 has the same problem but see how it is doing this problem. If my wife push the express button let say for potatoes and time 3 for 3 potatoes it start and when finish she open the door and the crazy microwave start but the turntable does not turn. It sound like only the fan is working. and no matter how many times you try it the fan start again. The only way to clear this problem is to shut off the breaker and reset it. On all the regular other push your time there is no problem. Our trailer just turn over a year last week and I am planning to call Hamilton Beach this morning to complain. We used this oven only a few times and this is the model HB909H3B. What a crappy affair and I am trying to find another make that will fit in the faceplate that came with the microwave and I cannot duplicate the opening. If someone can help me to see I there is a fit model I would be very happy.
capucine is offline   Reply With Quote
Old 10-11-2011, 07:32 AM   #12
frankm's Avatar
Good luck with Hamilton Beach. We also have the same MW and recently experienced some issues with it (it completely died, as in no control panel lights, no nothing. Checked breaker and GFI's, all fine. Five minutes later the MW started working again. Brought it home, tested for long periods and it worked fine everytime. For now I'm just going to assume it may have been due to low voltage at CG. Will know next time out). Anyhow, I called HB customer service and they claimed that the had nothing to do with MWs bearing their name brand!! Called our dealer and at least he said if it happened again he would look at our unit and if necessary replace it with a Magic Chef mw. Fingers crossed!
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 10-12-2011, 07:27 AM   #13
frankm: Yesterday I made more investigation on this microwave. First I tested the oven with a radio set on AM station. If you bring a radio with a AM band close to the microwave when it is working you will have a lot of noise and static in the radio everytime the magnetron comes in action. For our problem when it still work when the door is open there is no microwave action at all except that the fan in action. The turntable dont even turn. After letting the fan running for a minute with the door open I heard a click and the fan shut off. Also this issue only happens when the microwave is hot after let say running for 5 minutes. These microwaves are running very hot because of the lack of ventillation except the tront plate grill. I am starting to think that this issue is normal except that it is not written in the owner manual. I cannot email them because the email in the book is not in service. Called my dealer and he said that they will try to give me a number to call and a new microwave is $500. I cannot believe this when you can get a .9cu at wall mart for$70. Still a crappy affair!!!
Old 10-12-2011, 05:14 PM   #14
frankm's Avatar
Also this issue only happens when the microwave is hot after let say running for 5 minutes. These microwaves are running very hot because of the lack of ventilation except the front plate grill. I am starting to think that this issue is normal except that it is not written in the owner manual.
capucine, I follow your thinking and would tend to agree. Ironically both of our issues were started by potatoes!
However my MW quit working altogether and it wasn't until about 5 or so minutes had elapsed (MW cool down time?) that it would come back to life. It did it twice then for safety reasons we didn't attempt to use it again. When I tried to replicate the issue here at home (MW out of the trailer connected to house ac outlet) it worked flawlessly. We put it back in the trailer just this weekend and tried it again. It also worked flawlessly, thus my reasoning that it did what it did due to low voltage at the CG we were at.
If what we are experiencing are undocumented "features", I can tell you: I don't like undocumented features in microwaves!!
Frank & Rita M
Old 10-13-2011, 08:54 AM   #15
jimh's Avatar
is ur microwave built in? if so there should be a fan to move the air from around the enclosure (in addition to the fan built into the microwave to cool the magnetron). make sure that is running. heat build up may be causing ur problem.
jimh is offline   Reply With Quote
Old 10-13-2011, 09:39 AM   #16
frankm's Avatar
Yes it is a built in mw but there isn't an additional circulating fan. What the mw has is an add-on air duct contraption attached to the top of the mw (not visible from the outside) that channels the air out the front grill vents. If it does turn out to be an over heating (I have used this mw for over a year w/o a problem) then I will consider cutting an opening here (see yellow arrow in pic) and use a black screen or in-wall speaker cover to hide the opening.
Frank & Rita M
Old 10-13-2011, 12:13 PM   #17
jimh's Avatar
they may have sized the fan in the microwave to accommodate the built in configuration. the only built in i had played with had an additional blower in the back to force the air thru there.
it sounds like the control panel. i was just trying to see if there was something else that may have caused it to fail.
in the case of my sharp, the panel was replaced twice under warranty. when it went out abt 3 yrs after warranty expired, i found the cost of the control panel was more than the original cost of the oven.
u may want to see if u can find one of the cheaper microwaves and see if u can set it in there and take ur chances.
Old 10-13-2011, 12:26 PM   #18
frankm's Avatar
Thanks jimh, for now I'm hoping that my issue was totally related to poor CG voltage (fingers crossed) and not anything else wrong with the MW or camper electronics. If not, I have already alerted our dealer and they are standing by.
Frank & Rita M
Old 10-14-2011, 03:54 PM   #19
I would still say that these microwave are running very hot and it is most of the problems with these issues. I called Hamilton Beach and they told me that they dont deal with trailer microwave oven. What a good service!!!!! Try their email at bestrvproducts and you end up nowhere.
