Originally Posted by BILL49
First let me say Thank you for your service sir.
When the TV scans for channels, it shows Analog, Digital, and RF channels found. When I do a scan it says it's found 69 RF channels.. no Digital or analog ones ...thena screen returns saying "Please run Channel Auto Scan" ..which I just did..I have the input set to air... I set it to cable also with similar results.
Bill, I think what your seeing is the actual channel numbers being scanned, ie; 2-69. Those are the original VHF & UHF band channel numbers.
Then, as it counts up those numbers, if it should find a good signal it would then show in the digital or analog column (for over the air antenna, it should only find digital channels, analogs were phased out in 2009 - 2010). The only time you should get any analog channels is when you're hooked to a campground or household CABLE system because some cable systems take the digital signals and send them through the cable in analog form.
So, now, it seems to me that you have a loose or no coax cable connection between the Jack antenna signal indicator or antenna booster & the back of your Tv. Check for proper and or loose connections between the Jack antenna/antenna booster etc. Manufacturers have been known to forget to connect or left them loose.
2014 Prime Time Sanibel 3250
