Old 04-24-2014, 11:43 AM   #1
Soxfan1957's Avatar
Heat & A/C on together
Last weekend I took my Sabre out for the first time this year. After the long winter, just couldn't wait to get out again. So it's our shakedown trip to see that all is working the way it should. Well, when we got to our site, and got all set up, I turn on the gas and fire up the furnace, and both the heat and the a/c both come on. So I shut off the circuit breaker for the a/c. So I'm thinking I need to replace the thermostat. Does anyone else have any other theory's?
Sent from my DROID RAZR HD using Forest River Forums mobile app
Soxfan1957 is offline   Reply With Quote
Old 04-24-2014, 11:49 AM   #2
bubbles's Avatar
Could be your fan mode is set to HI or LO and should be set to AUTO.
Old 04-24-2014, 11:54 AM   #3
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
I think bubbles hit it on the head. I read my owners manual last night for my 2015 Wildcat and it said the exact same thing. Thermostat needs to be on auto, if on high or low air conditioner fan will run also.
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnegbago Adventurer 38Q....26K Chassis
...traded in 2015 FR Wildcat 282RKX
2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
Cover Dog is online now   Reply With Quote
Old 04-24-2014, 12:14 PM   #4
nuisance's Avatar
That is what fixed mine last year
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 04-24-2014, 12:19 PM   #5
Soxfan1957's Avatar
Thanks. I will check that out when I get home from work.
Old 04-25-2014, 07:33 AM   #6
X2. Look on page 9 of the T-stat manual.
Old 04-27-2014, 07:17 AM   #7
If the fan switch was set to auto, you may have a stuck relay on the AC. I had this to happen on my home AC, ants got in relay ,it can cause it to stick on or off.
jerry1946 is offline   Reply With Quote
Old 04-27-2014, 07:20 AM   #8
davel1971's Avatar
its normal like most others say. Just turn AC breaker off when using heat like you've already done
David & Lynn
Old 04-27-2014, 07:26 AM   #9
Oklahoma Proud
MillerTime's Avatar
X5 or 6 on the thermostat being on auto, just switch to high or low, or switch to auto if on high or low.
(Sorry cant remember which is which, ive only used the furnace 1 time)
MillerTime- Future Sabre Handler!!
Old 04-27-2014, 07:32 AM   #10
davel1971's Avatar
or turn breaker off and set fan wherever you want and don't worry about it
David & Lynn
