Old 03-31-2014, 09:35 AM   #1
Heat/Cool pump vs. Furnace and AC
We are considering buying a trailer and are wondering about the efficiency of a heat/cool pump. What is the maximum outside temperature that a h/c pump can keep the inside 'comfortable'? And, what would be the minimum outside temp?
Also, are there any MAJOR pros or cons for each? Thanks for your replies.
alpineskier is offline   Reply With Quote
Old 03-31-2014, 10:10 AM   #2
Heat pump much more efficient and should work until the outside temp gets close to freezing. The down side is you must have AC power for it to operate. The furnace will operate on 12VDC.
cadman99 is offline   Reply With Quote
furnace, pump
