Old 03-11-2015, 01:20 PM   #1
Jemma's Avatar
Question Heat Only Coming From One Vent
Maybe this is a better place to post than the propane area.
I have a 2014 Forest River Wildcat Maxx, and the heat is only coming out of the vent under the kitchen counter, under the drawers in the peninsula. The vents close by seem to have some heat barely trickling out, but none of the other vents are working.
Does anyone have any advice? Thank you so much in advance for whatever help is offered!
Jemma is offline   Reply With Quote
Old 03-11-2015, 01:58 PM   #2
jtstromsburg's Avatar
First, If possible, find your furnace and make sure the ductwork is hooked up correctly. Sometimes the ductwork (similar to dryer vent duct) becomes unattached to the furnace openings. It's also possible that the ductwork had become crushed in areas.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 03-11-2015, 02:13 PM   #3
Might be a funny question but can you hear air escaping anywhere other than that vent you said is working? As stated above it may be the ducting is not attached or has become unattached or even pinched somewhere.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 03-11-2015, 02:20 PM   #4
Biscuit's Avatar
I have found holes in the ductwork under the floor and also mouse nests in the ductwork, each of which blocked the airflow at the vents.
2006 Chevy Silverado 2500HD
2012 Rockwood 2902SS
Biscuit is offline   Reply With Quote
Old 03-11-2015, 03:21 PM   #5
Jemma's Avatar
This kind of freaks me out......
I have an aversion to hauntavirus.
Old 03-12-2015, 11:50 AM   #6
brer_rabbit10's Avatar
Do you get Hauntavirus from ghosts?
Bill Case
Silverback 35QB4
F350 Diesel prime mover
brer_rabbit10 is offline   Reply With Quote
Old 03-12-2015, 11:59 AM   #7
Witch Doctor's Avatar
Sounds like your duct work was not connected and your probably feeling air from the underbelly. You are going to have to check the furnace, either the ducts are not connected correctly or you have some crushed somewhere. Sorry to say that's a pretty common problem with FR....
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-12-2015, 12:47 PM   #8
We have 2014 rockwood, we found that they had left chunks of Styrofoam in some of the ductwork. This was blocking the flow of air to the bed room until we finally got it out.
sixstring is offline   Reply With Quote
Old 03-12-2015, 04:05 PM   #9
Suggest you check duct as others say.
In our 21FBRS we found 4" flex duct kinked with no air passing thru. Easy fix.
Henboy is offline   Reply With Quote
Old 03-12-2015, 06:02 PM   #10
geotex1's Avatar
Yep, check the ducts. Our 232 has a short, tight turn to a wall vent in the bathroom. No problem during PDI, but second trip needed heat. Bathroom was chilly along with bedroom. Saw DW standing in front of intake grill, and she said she was enjoying the warmth! I pulled off the grill and there was a 12" separation in the foil duct dumping all the warm air! Just made Home Depot before closing.
geotex1 is offline   Reply With Quote
vent
