Old 10-26-2013, 08:50 AM   #1
Chrisbrock's Avatar
Send a message via Skype™ to Chrisbrock
HEAT Pump stopped working
So as always I left the heat pump on over night in the RV to keep the chill out. Last night it dropped into the 30's and the heat pump this morning when I got up was not working.
Any input?
Christopher Brock
2014 Sunseeker 3170ds
2012 Honda Odyssey
2003 Hummer H2
2003 IS300
Chrisbrock is offline   Reply With Quote
Old 10-26-2013, 08:57 AM   #2
Chrisbrock's Avatar
Ok so from what I am reading under 40degrees outside and the heat pump will lock out.
So in this case do I run a small space heater in the coach or kick the furnace on?
I use my RV year round for work so winterizing is not a option. I keep the water heater on to make sure it doesn't freeze over.
Any other tips for year round use in the cold would be great.
Christopher Brock
2012 Honda Odyssey
2003 Hummer H2
2003 IS300
Old 10-26-2013, 08:57 AM   #3
Ford Idaho's Avatar
That is how they work I guess, several posts here and other forums say around 40 or less you need to go with the furnace.
https://www.google.com/search?q=heat...s.com&x=36&y=7
If you want to keep your propane usage down then use a space heater of your choice.
Do you have skirting on?
Is your water and drain hoses insulated and covered?
pump
