Old 02-03-2019, 05:43 PM   #1
mike.t's Avatar
Heater
I have a winter question, I want to set up a heater in the trailer on a timer, it's going to get into the teens for a few days. Trying to set the timer to come on for an hour, shut off, then come back on at later set times. Once the heater shuts off you must manually push the on button, any tricks?
Mike
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
"If you can't fix it with a hammer, you've got an electrical problem"
mike.t is offline   Reply With Quote
Old 02-03-2019, 05:53 PM   #2
does it have a thermostat you can set to turn on and off instead of timer? I have 2 10$ heaters from lowes that have a dial adjustment for temp.
Kimber45 is offline   Reply With Quote
Old 02-03-2019, 06:40 PM   #3
mike.t's Avatar
Thanks kimber. the one I set up does not but i may have one that does,
Mike
2014 Dodge Durango
Old 02-03-2019, 06:51 PM   #4
western NC mountains!
formerFR's Avatar
we just use a simple electric heater which has it's on 'thermostat' and comes on whenever it's needed, whether we are there or not
formerFR is offline   Reply With Quote
Old 02-03-2019, 07:16 PM   #5
Mike
if you're talking about an electric heater just buy one that doesn't need to have a button pushed when power has been interrupted
MR.M is offline   Reply With Quote
Old 02-03-2019, 07:42 PM   #6
dbledan's Avatar
If your heater can just turn on without having to push anything to turn it on I would suggest a termocube. On at 35-Degrees/Off at 45-Degrees...if you want different temps then get a heater with a thermostat.
dbledan is offline   Reply With Quote
Old 02-03-2019, 08:05 PM   #7
$20 at Walmart:
https://www.walmart.com/ip/Utility-M...1702/642591645
Probably a LOT easier than screwing around with what you've got.
Not sure I'd even want what you've got. A one-time timer isn't what you want/need.
2011 Traverse LT, 3.6L, FWD
Old 02-03-2019, 09:03 PM   #8
Thermo Cube
https://www.amazon.com/Farm-Innovato...ds=thermo+cube
opens(comes on) at 35 deg, closes(shuts off) at 45 deg, I've used this for 23 yrs using 100 watt light bulbs to heat my pump-house, ... handles 15 amps, so a heater is no problem, ... actually the original one lasted those 23 yrs, cause I just replaced it three weeks ago, ... not really sure that one is bad, it just wasn't on at a time when I thought it should be and since it's that old, and since I had a new spare, I replaced it, ... I'll check it further before I throw it away, ... can order from Walmart for the same price as Amazon, ...
fella10 is offline   Reply With Quote
heater
