Old 05-15-2019, 07:26 PM   #1
LIW
Heater (furnace) short cycling
My Atwood heater is short cycling. I have taken off the cover and do not see any lights on the panel lit up. Thought it may have been the propane regulator (i have a dual tank regulator that hooks up to both tanks with a dial that determines which tank i use), but when i check the stove, i get a strong propane flame.
Any suggestions of what to look for?
LIW is offline   Reply With Quote
Old 05-16-2019, 12:11 PM   #2
Head Rambler
Short cycling can be caused by the thermostat. Which thermostat do you have?
Has it ever ran normally?
It could also be caused by a few other things. Describe exactly what's happening?
How long does it run before it shuts down?
If you turn off the thermostat and turn it right back on will it start back?
Does it make any odd sound just before it shuts down?
Are any of the registers blocked?
Is there good airflow out all the registers?
Gotta go campin!
Old 05-16-2019, 12:23 PM   #3
Just as confused as you
Scrapper's Avatar
Is the cold air return blocked by a cooler, case of beer or soda, anything that could block more than 25% of the intake grill?
Richard & Jill
Camping since 1989, seasonal since 2000
Scrapper is online now   Reply With Quote
Old 05-17-2019, 09:51 AM   #4
Usually short cycling is caused by the high limit switch being activated. It's either a lack of airflow (blocked vents/intake) or a bad switch.
Abendage is offline   Reply With Quote
Old 05-19-2019, 08:22 PM   #5
Or, a slow blower motor.
n0ms is offline   Reply With Quote
heater
