Old 08-28-2013, 07:02 PM   #1
Heater Help
When we turn the furnace on, the air conditioner comes on. We have to*turn off the 30 amp breaker and it turns off many electrical receptacles.
WE HAVE A 2013 Surveyor Sport with a Suburban air conditioner/furnace.
Gensca is offline   Reply With Quote
Old 08-28-2013, 07:04 PM   #2
TURBS's Avatar
Turn your fan to auto not "on" at the thermostat.
turbs
Old 08-28-2013, 07:51 PM   #3
Thanks but It does not have an auto.
Old 08-28-2013, 07:54 PM   #4
We are in the Yukon and we could really use the heat!
Old 08-28-2013, 08:01 PM   #5
TURBS's Avatar
does your thermostat look like this ?
It has a "auto" function as well as a " on " function, you may not know how to use your thermostat.
Old 08-28-2013, 08:04 PM   #6
TURBS's Avatar
If you have the above thermostat read page seven I believe of this manual.
http://www.google.com/url?sa=t&rct=j...51495398,d.aWc
turbs
Old 08-28-2013, 08:15 PM   #7
No...almost...but it does't have "heat pump".
Old 08-28-2013, 08:23 PM   #8
TURBS's Avatar
Without the model of thermostat I cannot help you get your fan to auto.
TURBS
Old 08-28-2013, 09:07 PM   #9
Fulltime family RVer
Yours and mine are the same. It's actually the "fan" that is coming on, not the A/C (they both sound alike- the fan just doesn't kick on the A/C compressor to make cold air).
To get the desired behavior:
Push the button until you the light is on for "Fan". Change it from "Hi" or "Low" (or even just "On") until it says "Auto".
Then go back to furnace and turn it to the temperature that you're after. The fan in the A/C shouldn't come on now.
Old 08-28-2013, 09:55 PM   #10
avolnek's Avatar
Turbs and Doug have you headed the right direction. Select the "fan" via mode button and the press + or - till it says auto.
Let us know if that does the trick.
Turbs... Heat pump... Really!? :-)
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
heater
