Old 12-28-2014, 11:45 AM   #1
HEATER issues
I have a stealth wa2715g 2014 and when the heat is on and i start the generator to watch tv the air conditioning unit comes on on the roof how do i get this to not come on and blow cold air while my furnace is blowing hot air out of the furnace vents on the bottom
detailmgr is offline   Reply With Quote
Old 12-28-2014, 11:51 AM   #2
wmtire's Avatar
If you have a digital thermostat, then you need to make sure the fan setting is turned to automatic.
Heating - A/C issue
2011 Flagstaff 831 RLBSS
Words are powerful.
Choose them good.
Old 12-28-2014, 12:05 PM   #3
thank you. i feel like a fool
Old 12-28-2014, 12:38 PM   #4
wmtire's Avatar
No, there's no need for that. It's a pretty common thing that could be documented better by the manufacturer.
The reason these forums exist, is to share collective knowledge, and help each other out.
Words are powerful.
Choose them good.
Old 12-28-2014, 01:15 PM   #5
Old Timer
AC fan + heeater?
According to Dometic, this feature allows you to circulate more air when the heater is running. Never tried that. Not sure if it makes sense, but it took me a while to figure out how to stop the AC fan the first time it happened...and maybe the second.
kentnjudy is offline   Reply With Quote
heater
