Old 09-29-2008, 11:56 AM   #1
Heater Problem
While camping in our 2009 Rockwood 8317ss the heater stopped working in the middle of the night. We thought we were out of fuel, so we switched to the other tank. This seemed to work.
When we got home we discovered that the fuel tank we thought had run out had not. We then tested out heater and the fan will come on for about 15-20 seconds and then nothing. It doesn't matter how high we set the thermostat the same thing happens.
It is a suburban gas heater.
Any Suggestions?
Jen & Fred plus 3
2009 Rockwood 8317SS
2008 Ford F150
justthe5ofus is offline   Reply With Quote
Old 09-29-2008, 01:00 PM   #2
Grape Escape
Sounds like propane tank froze off. Try shutting it off disconnecting hose and try again
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 09-29-2008, 01:22 PM   #3
Thanks That's not the problem. The stovetop lights so the gas is working. Just not the heater.
DH called the dealer and is taking it over first thing tomorrow. They're hoping it's a bad circuit board, a simple fix to replace. We leaving Thurs for a 5-day trip to the Poconos so we can't leave it at the dealer. Wish us luck!
~Jen
Jen & Fred plus 3
2008 Ford F150
Old 09-29-2008, 04:41 PM   #4
Head Rambler
Is the heater heating when it does run? if it's not lighting at all it could be the sail switch. Sometimes a blocked (or even partially blocked) register will cause the unit not to have enough air flow to trip the sail switch so it won't light.
Gotta go campin!
Old 09-30-2008, 07:22 PM   #5
THanks for the replies. We took it in today. They said it was a loose sparkplug. It's working now.
Jen & Fred plus 3
2008 Ford F150
Old 09-30-2008, 11:41 PM   #6
Smile
I experienced the same problem during our 5 week summer vacation. Turned on the heat at the thermostat and the furnace fan came on sounding like it would light but just kept the fan running. My first thought was that it might be something to do with my digital thermostat as I recently installed one this year. As time progressed during the holiday I noticed that when switched to the other tank everything ran fine. When on the opposite tank, everything but the furnace ran. I talked to a buddy of mine and he figures that it is something to do with the propane tank itself and to burn of all of the gas in that tank and since he is certified to work on these things he will change the valve.
I suspect that maybe the valve is not allowing enough gas or too much and the furnace may have some sort of sensing unit that recognizes this and will not ignite the gas. (fan just keeps running and will not ignite). I will let you know what happens when we change that bottles valve.
OREGONCAMPER
2008 Rockwood 8317SS - 2010 F150
2013 Camping Days: 22
2012 89 2011 50 2010 61
OregonCamper's Pics click here
OregonCamper is offline   Reply With Quote
