Old 06-29-2015, 07:43 PM   #21
Propane/ electric ...
normal camper style fridge
Samwar3 is offline   Reply With Quote
Old 06-29-2015, 07:53 PM   #22
RSchleder's Avatar
[QUOTE=Samwar3;908946]Okay, she's moved and my 50' 12-2 cord reached.
I'm going to let her sit for an hour or so then turn the fridge back on.
That long enough??[/QUOTE
No need to wait an hour, fire it up NOW!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 06-29-2015, 07:54 PM   #23
Okay... no need to wait and let the "stuff" settle like a regular fridge??
Old 06-29-2015, 08:11 PM   #24
When it is under heat, it causes the amonia mixture to rise from the bottom vessel(round tank) to the top of the tubing grid. When not under heat from (propane, electric element) the mixture returns to the round vessel. After it settles, put it under propane as the heat source (set button to gas only). I say that because you are running a 50ft.12/2 extension, and you can't be sure your gettiing enough current to the electric heating element, for sufficient heating of the amonia mixture and thus the cooling result. You will however, under propane heat. But, plug in your RV, so the piezo ignitor drawing current, does not run your batts down.
Old 06-29-2015, 08:16 PM   #25
Awesome, going to turn it on now.
Mine has an automatic power switch.
Old 06-29-2015, 08:24 PM   #26
Flybob's Avatar
As it started to work then quit, it is most likely due to being out of level. 12deg is way too much. The ammonia boils due to the heat. It then condenses back into the heating chamber where it evaporates again. If the unit is not level, after condensing it will not flow ( or at least much of it will not )) back into the heating chamber to start all over. Prolonged use when not level can damage the fridge.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-29-2015, 08:29 PM   #27
Just turned it back on.
Fingers crossed for dumb luck.....
Old 06-29-2015, 08:34 PM   #28
Exactly, and when engaged the default is to the 110v side. Just trying to eliminate a low voltage issue, thats why I suggest propane as your heat source.
Old 06-29-2015, 08:48 PM   #29
Gotcha !!!
Old 06-29-2015, 09:02 PM   #30
Thank you all for your fast help and info!!!
She is cooling off like a champ now !!!
Ya'll really are awesome !!
