Old 01-19-2016, 01:01 PM   #1
nuisance's Avatar
HELP !!!!!!!!!!
2001 Cherokee Greywolf
power surge, surge protector popped. YEAH!!
fridge went to propane, reset breaker, set fridge to propane and then back to auto. Now the on light blinks, and the propane light also blinks. Propane is full, electrical is working. What should I check now?
Deb and Phil
Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 01-19-2016, 01:53 PM   #2
MNtraveler's Avatar
HELP !!!!!!!!!!
Check that propane valve is open, then try for a clean, blue flame on the stove (using the exhaust fan). Then, once you have a clean gas flow confirmed, try restarting each of the gas appliances. Each one may take several tries to start.
Edited: oh, sorry, you said electrical is working again...turn refrig off and on again. If need be, try turning the breaker for it off then on again. (Perhaps just because after resetting breaker you went to propane first then auto. This time reset breaker with the refrig off, then go to auto.)
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 01-19-2016, 02:09 PM   #3
Flybob's Avatar
The surge guard is most likely no good anymore. If PI call and they will replace it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-22-2016, 04:47 PM   #4
nuisance's Avatar
had service man out today, found out the reset breaker case is broken, maybe the board too. Do I have it fixed here in Texas (we are wintering here) or wait for the Rally in Goshen? Fridge does work on propane so no problem there.
Deb and Phil
Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
Old 01-22-2016, 05:40 PM   #5
MNtraveler's Avatar
Wouldn't you like to stop paying for propane? (Assume you are already paying for electricity so additional use would be free.)
Land of 10,000 Lakes
2016 Forester MBS 2401R
