Old 11-05-2015, 08:38 PM   #11
TURBS's Avatar
There's several fuses behind fridge in outside panel.
Lower right behind a black cover.
You do have a full battery right?
Old 11-05-2015, 08:40 PM   #12
Yes battery is full. My husband is outside while I'm inside watching it attempt to ignite.
ApexBunk is offline   Reply With Quote
Old 11-05-2015, 08:41 PM   #13
VinceU's Avatar
Level will not prevent lightoff, do you also have 120 volt 2 way fridge? Meanwhile most common cause of no light is misalign of igniter or gas blockage( less common). Can you reach in with barbecue hand lighter while it runs start up mode?
VinceU is online now   Reply With Quote
Old 11-05-2015, 08:49 PM   #14
Yes it's a120 volt 2 way fridge. Husband just tried using BBQ lighter and ... THAT WORKED. thank you!
What does that mean for us? It's brand friggin new.
2016 Apex 300BHS
TV: 2005 Silverado Z71, 4x4 lowered and re-geared
Old 11-06-2015, 05:28 AM   #15
It means the spark igniter is not working or not aligned properly.
harderd is offline   Reply With Quote
Old 11-06-2015, 05:43 AM   #16
KDHfan's Avatar
2015 Coachmen Apex 288BHS
2014 Tundra 5.7 CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 11-06-2015, 07:53 AM   #17
Very thankful for this forum. Thank you everyone who chimed in so quickly to help us.
2016 Apex 300BHS
Old 11-06-2015, 12:01 PM   #18
Have you had it running on elect. ? Is the refrigerator cold and you just want to start running it on gas. If so it may be cold enough. and wont ignite the burner till it needs to get colder. Remember there is NO pilot on the new models.
hillsdaletc is offline   Reply With Quote
Old 11-06-2015, 12:18 PM   #19
Check your 12V battery charge sounds like the gas valve is not opening that is controlled by the circuit board that needs 12 volt DC very common problem I have seen. Good Luck
Egorsurf is offline   Reply With Quote
Old 11-06-2015, 12:46 PM   #20
I'll answer this as best I can. It ran on gas before our trip 2 weeks ago, and then turned onto electric at the campsite. It sat for 2 weeks and then we attempted to light it yesterday. Can you elaborate on the No pilot on newer models part? We could see the flame attempting to ignite last night but nothing happened. You could even hear the puff of flame but it never caught and would then start the cycle again. Hope that makes sense.
2016 Apex 300BHS
fridge
