Old 11-05-2015, 09:13 PM   #1
Help! Can't get fridge started
Hi all,
We are brand new TT owners. We have a 2016 Apex BHS300 we got less than a month ago and We leave out of town for the weekend tomorrow for its second outing but can't get the refrigerator to light. We have a Dometic fridge and we can hear it clicking going through its cycle and then nothing.
We ran the stove and that's working fine. We've attempted this for over 30 minutes and it will not light. We went camping just over a week ago and it worked.
What else can we try?
ApexBunk is offline   Reply With Quote
Old 11-05-2015, 09:21 PM   #2
TURBS's Avatar
It's possible there's that much air in the line.
It may have never been bled out.
Old 11-05-2015, 09:22 PM   #3
Even if we used it just over a week ago?
2016 Apex 300BHS
TV: 2005 Silverado Z71, 4x4 lowered and re-geared
Old 11-05-2015, 09:24 PM   #4
KDHfan's Avatar
Sometimes if I turn my propane off at the tanks, the fridge takes a while to start when I turn it back on (30-min seems excessive). I would try turning on your stove and let it burn for a couple minutes, then turn on the fridge while they are still burning.
2015 Coachmen Apex 288BHS
2014 Tundra 5.7 CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 11-05-2015, 09:24 PM   #5
TURBS's Avatar
You never mentioned that, which would have helped.
It's possible that a spider made a Web in the burner.
Can you blow it out with compressed air
Old 11-05-2015, 09:26 PM   #6
KDHfan's Avatar
Is your camper level?
Old 11-05-2015, 09:28 PM   #7
Everything is lighting. We have turned the stove on and let it run multiple times. The ignition is sparking but does not light.
2016 Apex 300BHS
Old 11-05-2015, 09:32 PM   #8
TURBS's Avatar
Propane valve may be bad or there's no power to it.
What is the fridge make and model?
Old 11-05-2015, 09:33 PM   #9
Mostly. Husband is leveling it now to see if that's the problem. 😳 that would be embarrassing.
Old 11-05-2015, 09:36 PM   #10
Would the check light come on after it cycles with no power? I don't know the model off the top of my head. Will get that if this doesn't work.
Old 11-05-2015, 09:38 PM   #11
TURBS's Avatar
There's several fuses behind fridge in outside panel.
Lower right behind a black cover.
You do have a full battery right?
Old 11-05-2015, 09:40 PM   #12
Yes battery is full. My husband is outside while I'm inside watching it attempt to ignite.
Old 11-05-2015, 09:41 PM   #13
VinceU's Avatar
Level will not prevent lightoff, do you also have 120 volt 2 way fridge? Meanwhile most common cause of no light is misalign of igniter or gas blockage( less common). Can you reach in with barbecue hand lighter while it runs start up mode?
Old 11-05-2015, 09:49 PM   #14
Yes it's a120 volt 2 way fridge. Husband just tried using BBQ lighter and ... THAT WORKED. thank you!
What does that mean for us? It's brand friggin new.
2016 Apex 300BHS
Old 11-06-2015, 06:28 AM   #15
It means the spark igniter is not working or not aligned properly.
harderd is offline   Reply With Quote
Old 11-06-2015, 06:43 AM   #16
KDHfan's Avatar
Old 11-06-2015, 08:53 AM   #17
Very thankful for this forum. Thank you everyone who chimed in so quickly to help us.
2016 Apex 300BHS
Old 11-06-2015, 01:01 PM   #18
Have you had it running on elect. ? Is the refrigerator cold and you just want to start running it on gas. If so it may be cold enough. and wont ignite the burner till it needs to get colder. Remember there is NO pilot on the new models.
hillsdaletc is offline   Reply With Quote
Old 11-06-2015, 01:18 PM   #19
Check your 12V battery charge sounds like the gas valve is not opening that is controlled by the circuit board that needs 12 volt DC very common problem I have seen. Good Luck
Egorsurf is offline   Reply With Quote
Old 11-06-2015, 01:46 PM   #20
I'll answer this as best I can. It ran on gas before our trip 2 weeks ago, and then turned onto electric at the campsite. It sat for 2 weeks and then we attempted to light it yesterday. Can you elaborate on the No pilot on newer models part? We could see the flame attempting to ignite last night but nothing happened. You could even hear the puff of flame but it never caught and would then start the cycle again. Hope that makes sense.
2016 Apex 300BHS
fridge
