Old 04-09-2015, 11:53 AM   #21
ov845's Avatar
Good at least they found the issue. What I did with ours is tied it all to 1 receiver using a 3Ghz splitter. No relocation or swapping coax. All our video goes thru a video controller. That way each TV is independent but in using the satellite all TV's watch the same channel.
ov845 is offline   Reply With Quote
Old 04-09-2015, 02:16 PM   #22
Ov845,
Can you elaborate on your set up? Mine was wired backwards and now I have to take the receiver to the bedroom to watch it up there. The outside and living room tv are tied together(the receiver goes In livingroom)
so we can watch the outside tv without takin the receiver outside. Thank you
kennithbk is offline   Reply With Quote
Old 04-09-2015, 07:17 PM   #23
ov845's Avatar
Sure, my first choice in watching programming would be satellite. All my sources meet in the living room (antenna, cable & satellite). All the gray coax cables lead to the TV's. I tied our bedroom with the outside since we're only using 2 TV's using a 3 Ghz splitter then connecting to TV 2 on the video controller. Living room TV is connected to Main TV on controller. Satellite connected to Satellite controller, Antenna & Cable share the same feed in at a Winegard faceplate, so I just connected to Antenna on controller. Bluray also connected to controller. The controller has different selections for each TV. So one can watch satellite in all the TV's or just one, same with antenna, cable or bluray. Or each TV can watch separate sources.
Here's pictures of the controller
Name:   ImageUploadedByForest River Forums1428624992.028437.jpg
Name:   ImageUploadedByForest River Forums1428625007.669405.jpg
Old 04-09-2015, 07:18 PM   #24
ov845's Avatar
I hope this helps you.
sandpiper
