09-21-2015, 03:51 PM
#21
Ok, thank you! one thing I just thought while researching that model, what if it's the 30 amp breaker on my converter that went out? How would one test to see if that breaker is bad?
09-21-2015, 03:54 PM
#22
Originally Posted by Bama Rambler
Best Converter recommends the WFCO 8735P as a replacement for the Centurion 3000. That's the way I'd go.
^X2^
I believe the Centurion 3000 is no longer made.
Get the WFCO model.
See it here:
Centurion CS 3000 Replacement
09-21-2015, 04:09 PM
#23
I'd call best converter and ask them.
I would not stick a wfco in anything.
Www.bestconverter.com
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
09-21-2015, 05:16 PM
#24
Progressive is the standard in replacement converters. I have read the other entries of this thread and feel your problem is indeed the converter. Best converter will guide you to the correct progressive for your unit or you can contact them direct.
09-21-2015, 05:25 PM
#25
Originally Posted by TURBS
Hmmm... The link I posted to Best Converter web site suggests a WFCO model as a replacement for the 3000. Are you saying to call BC and ask them to suggest something other than what they have already endorsed?
09-21-2015, 05:37 PM
#26
Yep!
TURBS
2011 32bhok Sabre
09-21-2015, 10:23 PM
#27
I would also ask for a Progressive replacement, as I feel Progressive makes a better converter than WYCO.
2021 Forest River Vengeance Rouge Armored 371A13
2021 GMC Sierra/Denali 3500HD SRW
Anderson Ultimate 24k Hitch
09-22-2015, 05:49 AM
#28
I have used WFCO converters for years with no problems. They are good converters for a decent price. I wouldn't pay more for another manufacturer.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
09-22-2015, 06:07 AM
#29
There's better for not much more.
Better for your battery / batteries.
There's threads weekly about wfco converters going bad .
TURBS
2011 32bhok Sabre
09-22-2015, 06:47 AM
#30
Mine may shoot craps today or tomorrow, but have had WFCO converters for years and years and no problems with them or batteries. It's just a personal preference IMO.
If ours goes out, it will probably be replaced with another WFCO or maybe a Progressive if the prices are the same.
09-22-2015, 06:50 AM
#31
I've had WFCO converters in the last three RV's, and the last one lasted 9 years before I had a power surge take out the charging unit. The one before that lasted until we traded, which was about 5 years. Never overcharged the batteries and they were powered on all the time.
I can't say that PI isn't better, but I don't think WFCO is as bad as people think they are.
Saying that you hear of WFCO's failing every day and you never hear of PI's failing, doesn't say much if WFCO has 90% of the market share. (P.S. I don't know what market share WFCO has. That was just an illustration.)
Gotta go campin!
09-22-2015, 07:32 AM
#32
I've not had a problem with WFCO units that were in a couple of units we had.
They worked fine and never cooked the batteries.
Most everyone here seems to think Best Converter is the place to go for converters so I was surprised when it was suggested that you should contact them and ask them to recommend something other than what they had already recommended. ??
09-22-2015, 06:21 PM
#33
Is there a difference between the WFCO and the progressive, other than price. Our 2000 Flagstaff Pop Up is 15 years old and I don't want to spend anymore money then I have to considering we won't have this for another three years.
09-22-2015, 06:27 PM
#34
All around better charger.
With the charge wizard pendant you can also control charging rate!
TURBS
2011 32bhok Sabre
