Originally Posted by MikeyP
Help. I have a 2015 Sanibel 5th wheel. Today the hidden TV in the living room has decided to remain hidden. It nests in a faux mantle behind the electric fireplace. Breaker is OK and there is power to the switch but nothing happens when pressed. :
You say there is power to the switch. Was this checked with a meter?
Can you use a jumper wire to verify the switch isn't bad?
If there truly is power to the switch and the jumper wire doesn't make it work, then you're likely looking at the motor or a connection to it so start tracing that direction would be my advice.
