Originally Posted by LNad
Hi Mr. Dan, the camper is 5 days old...we assume battery is new as well...we don't have tester on site
OK, I'll make a couple of assumptions... and ask a couple of questions.
1. You're plugged in to campground power.... 30amp or 50amp?
2. You have no battery disconnect switch or, if you do, it's connected.
3. Your power center breaker for your converter is not tripped.
Does your microwave work?
Are your inside lights bright as you would expect?
Has it rained on your trailer recently?
You need enough battery power to drive the blower fast enough to close what they call a "sail switch". Failing that, furnaces don't work.
...... and we've seen a couple (or many more?) cases where the furnace's control board has been wet and stifled furnace operation.
I'm asking questions so your answers will help smart people solve your problem.
