Old 06-07-2013, 09:48 AM   #11
TURBS's Avatar
This is what I have and it works as op is requesting.
Old 06-07-2013, 09:50 AM   #12
Dave_Monica's Avatar
Does your thermostat look like the one pictured in this link?
Products - Dometic
Dave
Old 06-07-2013, 10:27 AM   #13
bubbles's Avatar
SYSTEM "OFF" = FAN "ON"... SYSTEM "HEAT"= FAN "AUTO". Can't have it both ways. The heater has to control the fan due to propane as a heat source fuel. You can select fan ON or AUTO using A/C and set the fan to HI or LO for the A/C fan speed. If in AUTO for A/C the fan speed will be HI.
Old 06-07-2013, 10:33 AM   #14
TURBS's Avatar
Not really sure what your getting at here.
Op wants furnace to run but also have a/c fan to run.
With the thermostat I have pictured it will work that way as we do it all the time to evenly heat the sabre.
Heat on
Fan on
Old 06-07-2013, 02:46 PM   #15
IHDRIDER00's Avatar
That is what I have. The fan won't run. Maybe getting ahead of myself. Just wanted to see if there's anything I can check. Before I try to use this thing. I'll go out tomorrow and check again. I have not tried to check it in A/C mode because I know the amprage is too low. Thanks All!
IHDRIDER00 is offline   Reply With Quote
Old 06-07-2013, 03:12 PM   #16
Depending on the size of your AC mine is 13.5K it will run on 15 amp as long as nothing else major is on the same circuit. When I first got my camper I didn't have a 30 amp outlet outside (that has been remedied) and we would turn on the AC and sit in the camper and watch TV. Pole Barn Camping at it's finest
RickV is offline   Reply With Quote
Old 06-07-2013, 09:58 PM   #17
VinceU's Avatar
Originally Posted by IHDRIDER00 View Post
Hi, New to this. I have a 3004 All American Sport 36CK. I have not taken this out yet. Sitting in the driveway. Plugged into an extension cord, 15amp. I know better than to try the A/C hooked up this way. But from what I have read here, if I understand correct, the fan should run in the fan on mode with the heat on. It does not. It has a Duo Therm thermostat. I'm wondering if something may be wrong? Is there anything I can check? Not taking this thing out till the end of June and don't want any surprises. Thanks
I understand your question (I think). In 2004 Dometic and others used analog thermostats, ie you manually chose your settings with switches. Now using the Digital round dial style you can choose the run the VENT fan in the ceiling w/ AC mandatory, circulate only or with heat. The purpose with heat is to move the heated air around far more efficient than the heater fan alone. It does work well that way. Hope this clears the air! I guess you could convert to the new system?
Old 08-04-2013, 06:54 AM   #18
IHDRIDER00's Avatar
Finally got to a CG, 30 amps. everything works great. Thanks All!
