Old 06-06-2013, 10:39 AM   #1
IHDRIDER00's Avatar
Help no a/c fan
Hi, New to this. I have a 3004 All American Sport 36CK. I have not taken this out yet. Sitting in the driveway. Plugged into an extension cord, 15amp. I know better than to try the A/C hooked up this way. But from what I have read here, if I understand correct, the fan should run in the fan on mode with the heat on. It does not. It has a Duo Therm thermostat. I'm wondering if something may be wrong? Is there anything I can check? Not taking this thing out till the end of June and don't want any surprises. Thanks
IHDRIDER00 is offline   Reply With Quote
Old 06-06-2013, 10:55 AM   #2
tanddc's Avatar
You did not say if it is digiatal or analog. On the digital, you need to go to the fan mode and set it on hi or low. You do not need any other mode on to run the fan.
tanddc is offline   Reply With Quote
Old 06-06-2013, 11:41 AM   #3
IHDRIDER00's Avatar
Not digital. In the fan mode, from what I have read, with the heat on, the fan should run. Unless I'm mistaken?
Old 06-06-2013, 02:42 PM   #4
Don't try to test by using an anomaly of some thermostats. I don't think they all do that, and why would you want it to? Just turn the fan on with the normal fan mode setting.
Old 06-06-2013, 02:55 PM   #5
Dave_Monica's Avatar
I believe that the AC fan should run by selecting On instead of Auto on the thermostat. It should also have a Hi/Lo switch.
The fan should run but the AC wouldn't start using a 15A outlet and extension cord.
I'm not sure I understand what you're trying to accomplish.
Dave
Old 06-06-2013, 02:59 PM   #6
TURBS's Avatar
Dave I "think" there trying to do what most people don't want to do or can't figure out what's happening.
Trying to run furnace and also have the a/c fan on at the same time.
Correct me if I'm wrong.
Besides I think he must have a space age prototype being a 3004.
Turbs
Old 06-07-2013, 09:12 AM   #7
IHDRIDER00's Avatar
Hey guys. Maybe I'm getting ahead of myself. 3004, maybe I am. I've read posts here about the fan running in the heat mode. And replies that it will run if in the on position. Mine will not. Maybe I'm over thinking this, but I want to avoid any posslble trouble down the road. Thanks, All
Old 06-07-2013, 09:16 AM   #8
Did you try what I suggested...the AC fan should run when 'On' is selected regardless whether you've selected AC or Heat.
Dave
Old 06-07-2013, 09:22 AM   #9
IHDRIDER00's Avatar
Yes, I tried when the heat was on. The fan didn't run. That's the reason for my question. Thanks
Old 06-07-2013, 09:46 AM   #10
caper's Avatar
If you have the older style thermostat you cannot run both at the same time. A picture of the thermostat would speak volumes. At the present time we can only guess as to why you cannot run both at the same time.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
